Question about Emerson MW8102SS 1100 Watts Microwave Oven
Emerson microwave: Control buttons work microwave does not
The microwave buttons and timer works. the microwave does not work not does the turnatable.
  • 2 more comments
  • Anonymous Mar 23, 2008
    The microwave wave was unplugged overnight. Still the same.
  • auntie pizza Mar 26, 2008
    everthing lights up all the buttons work but nothing works. a
  • Anonymous Mar 28, 2008
    same problem with Model mw8115ss
    same problem with Emerson Model mw8115ss
Sounds like the primary switch on the door latch is no good .had the same problem change it out and it works fine now.
Posted on Dec 27, 2008
  • 29 Answers
Consult your manual, but it might be in demo mode. Unplug it for about 10 minutes to see if that would help.
Posted on Mar 01, 2008
Emerson Microwave MW9117W. Timer Counts down and turn table stops, but continues to hum as if microwave is still running. Have to unplug to stop it. Anyone know what problem is? Thanks
Sounds like you have a ''smart board" or door switch problem, try to un plug the product, push all the 'buttons' on the control panel and then plug the product back in, if this does not correct the problem you have a component that has failed.
Jan 09, 2015 | Emerson Microwave Ovens
Emerson Microwave Model MWG 911156: I cannot determine how to set the hour on the clock. After I press the "clock" button, what do I press to get it to the correct hour?
Usually the minute and seconds or a combination of the timer buttons will work it. If it has no hour then the minutes must be used as a dual use button.
I have looked on the web and cannot find a photo of the front panel to refresh my memory.
Hope that helps.
Jan 19, 2011 | Emerson Microwave Ovens
My emerson just quick working the timer is on but it isn't doing anything. I unplugged it thinking it may have reset but it didn't. How can I fix it?
I have a similar issue with this machine. For your problem, try this...Press and hold the STOP button for three seconds. This is intended to turn off the "Child Lock Out" function. On the other hand, you may find that buttons that do not work today will be fine in a few hours and different buttons will not work. It seems that every time I press a button, it's "pot-luck" if it will work or not.
The only way to repair it is mail it to California at your own expense and include a check for $15.00 for handeling. Target won't help and if you bought the extended plan it only kicks in after the emerson waranty runs out. If you buy this machine, buy another brand as well so you have one that works while this one is out being repaired.
Oct 24, 2010 | Emerson 025806092806 Microwave Oven
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
'Start' button won't depress, seems jammed; timer knob broke off
the button is stuck because of food buildup over the years underneath the button, this happens even to newer ones after about a year of use, new microwaves are cheap and the lower end models start at only $35 from walmart I would reccomend buying a new one, newer microwaves use less power and are more effecient so a new one will pay for itself in saved electricty costs after about 2-3 years of use.
May 11, 2009 | Emerson Microwave Ovens
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson Problem
Your Control Panel has failed. Replacement of the Control Panel is your only repair option. Not cheap!
Feb 04, 2008 | Emerson MW8987B/W Microwave Oven
Emerson 600 watt microwave
disassemble it and look for disconnections to control panel from faulty factory assembly
May 30, 2007 | Emerson MW8627W Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
608 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
jason
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
