Question about Acer AL2016W 20" LCD Monitor
Brightness adjustment not very effective - XP-sp2
I can adjust brightness using front panel controls but the screen always appears too bright - how do I make (preferably) brightness fade to black?
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Posted on Mar 21, 2008
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
Adjust brightness
Hi Valerie.
Brightness is adjusted via keys on the keyboard or through the monitors/dispalys control panel in System Preferences.
If you have a screen that is excessively bright (which does seem to happen on these laptops) you may need to visit an Apple store to have it looked at. I've seen several where the screen is so bright it's difficult to read text and adjusting the brightness has not had any noticeable effect.
Dec 04, 2013 | Computers & Internet
Adjust screen brightness
Yopu can adjust the brightness of the monitor from the avaialbe panel buttons Alternatively you can do so from the Operating Sytem brightness control which depends on the platform you are using. If its windows you can navigate to control panel and the power settings and adjust the brightness by sliding the slide bar as desired.
Sep 21, 2013 | Hyundai ImageQuest Q17 17" LCD Monitor
Brightness adjust
There should be buttons on your screen which allows you to adjust the brightness! Otherwise you can look at display under control panel!
It should say in the manual how to adjust the brightness
May 21, 2013 | HP Envy 23-1070 All-In-One Desktop PC with...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
How to increase a brightness of screen
I assume you are using windows. Follow these steps to adjust the screens brightness:
- Go to the Control Panel - Go to display - On the left pane click adjust screen brightness - At the bottom of the screen you should see the screen brightness meter being displayed. Change it accordingly and then apply the settings to keep them.
Alternatively you should be able to adjust the brightness of your screen using the a combination of keys on your keyboard. This differs with the type of machine though
Jan 19, 2011 | Computers & Internet
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
What is "OPC"? It comes up and goes away.
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Adjusting Screen Brightness in Windows XP
Brightness is not adjusted within the windows operating system It is adjusted at the monitor.
Sep 10, 2008 | Apple MacBook PC Notebook
Acer AL2016W 20" LCD Monitor Logo
911 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
