Question about CMB T43 750 Notebook
No free space on d drive
I have 80% freespace on C drive but the D recovery drive is full with no space. Help
  • Anonymous Nov 26, 2008
    FORMATTED [D] DRIVE by mistake how do i correct
    Genius:
  • 3,587 Answers
Hmmm..well..this is not going to make you happy. Just did one of those myself, and had to re format the drive. You need at least 15% space to move around on a drive, and this one is most likely a virtual drive(carved out from C)..so, right click on it, and select format.
ALL your data is lost. Only other thing you might try is a remote backup of that drive.
click here for some of those options
Posted on Mar 01, 2008
My drive is full, I deleted files but it is still full. Can I compress the data
OK... have just the answer for you but you MUST have room enough for one more tiny program...
CCLEANER
Get it FREE from the links below!
Anthony
https://www.piriform.com/ccleaner/download
and the TUTORIAL is here:
How to use CCleaner tutorial Clean your Computer Free Easy
Dec 02, 2017 | LaCie 80GB Mobile Disk USB 2.0 80 GB Hard...
Can't install Alley 19 on XP.Says not enough hd space (has 31.9 Gbites freespace)Install only takes 38 mbites
Run in windows 95 compatability mode. Click on My Computer->right click on the cd drive->open-right click on setup->properties->compatability tab->choose windows 95 then run it.
May 12, 2012 | Masque Publishing Alley 19 Bowling
My D drive (system restore) only 10% of free space left. Should I be worried?
No, don't sweat it, nothing going to happen if it is full. Maybe a little slower, just don't try to save or install program that requires more then the freespace that is left on your harddrive.
Jan 23, 2011 | Computers & Internet
How to recover my files from HD? I have Western Digital External hard Drive 500 GB.It was nearly full, such there was only 50 gb free space. Day by day it worked slow and one day It stopped working, not...
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more how to get the job done from: http://www.western-digital-data-recovery.com/
Dec 27, 2010 | Western Digital Passport WDXML800UE...
Drive d full
format it or download a registry clearer if still you get the problem check for
virus.
Sep 19, 2009 | HP G60-235DX Notebook
My 32 gb pen drive is detected when it is connected to a pc but if itis right clicked and seen properties it shows used space 0kb and freespace 0kb ie it is corrupted can you please help me to fix this...
Your drive's filesystem is corrupted. Easiest solution is to format this drive again. And remember to perform a full format.
NOTE: All data will be lost on this drive if you format it.
If you also want to recover your data. Please download a copy of Hirens' BootCD (http://www.hiren.info/pages/bootcd) from here and burn it to a CD. Boot with this CD and select a recovery tool.
If found helpful, Kindly rate me.
Regards,
Waqar
Aug 03, 2009 | Electronics - Others
OLD FILE IS LIVING
because you didn't delete the old partition on the drive before istallation, when you goto install it inspects hdd and find other windows OS's before you setup a fresh install you hvae to get the blue screen to show all space as unpartitioned space then install as you did before
Apr 29, 2009 | Intel Motherboard
MY COMPUTER KEEPS TELLING ME IT HAS A PROBLEM
It sounds like you have been storing files on the Recovery partition (D:) instead of your C: drive. You should not do that. The Recovery partition should just that. If you need more space consider a USB external hard drive.
Oct 28, 2008 | Dell Microsoft Windows XP Home Edition
Need patch for free space 2 game to play in windows vista needs to recognize I have 4 gigs of memory
is it not installing,try to browse setup.exe or install file for the game,right click and choose run as administrator..it should be installed w/o any problems,or if you were able to install this and the game just crashes upon playing it,you need to put it to compatibility mode,To do this search for freespace.exe (Probably in C:\Program Files\Volition\", right click and select the "compatibility" tab. Check the box that says "run this program in compatibility mode for" and select "Windows 98"
Sep 29, 2008 | Computers & Internet
8 percnt freespace left on hard drive,desperately needs too d-frag
Good morning, doctor-e!
When you get the HDD this full, you will normally experience issues like you mentioned.
Without knowing what you have on this drive, I can only offer the following suggestions:
1-remove any old files, programs or clutter that you don't have any further use for.
2-If you have large amounts of audio and/or video files, back them up to a CD, then remove them from the disk.
3-Buy yourself a bigger drive. (An early Christmas present?)
Basically, you are going to have to clear up some space on your existing drive. The system uses the available clear space on the HDD for swapping files, running the programs and so forth. As the free space gets limited, the system will start having trouble finding enough space to do it's thing.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 08, 2007 | Computers & Internet
Computers & Internet Logo
261 people viewed this question
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
vojvodabudva
Masood Rasool
Level 1 Expert
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
