Control panel i cant find my control panel it is not in the start menu and i cant find it no where on my computer
    Sniper:
  • 74 Answers
Have you try "Search" then all file and folder and write "Control Panel" then sarch... if not you have to run a repair with the original operating sistem disk..it will fix the loose part of the OP....Good luck and rate me
Posted on Mar 01, 2008
The control panel isn't working properly. How do
Try getting in through the start menu, your documents, and your search bar. If all fails, then start your computers command prompt, (type in search button in start menu: "cmd") just type in: "start control" and press enter; the control panel will launch. Also, if you type "run" in your start menu search bar and type in control followed by pressing the enter key, the control panel should start up.
Jun 22, 2013 | Computers & Internet
Cant reformat my pny 4g flashdrive
click start click to open on my computer you should see your Usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps you
Mar 05, 2012 | Electronics - Others
I cant get in to my othere user act on my compter..
Well there are two ways to do this.
1. Login to your account, go to the start menu, control panel, user accounts
click on the user account you cant login to, click change password, change the password and logout. Login to the account with the new password. (Only works if you have a admin account)
Or
2. Go to the start menu, click on RUN. Type control userpassword2 . Uncheck the checkbox that says "Users must enter a user name and password to use this computer. Click apply, restart the computer. All set (Always works)
Have a nice day!
Aug 20, 2011 | Computers & Internet
Menu bar appears automatically in front of monitor and automatically uses it.
My SAMTRON monitor 56V is having a problem now..
The control menu of monitor settings which will appear
when the monitor control panel is pressed(Brightness,Contrast....) is coming frequently at my monitor without activation...
Now when the monitor is turned on, the control panel will come,and will not go even if we change the settings..
The control panel is switching between the CONTROL LOCK and UNLOCKED mode during each 5 seconds....So now I cant see anything on my screen
at the middle of the screen due to this overlaying settings panel.
I is giving the same effect as the Menu key is pressed in the panel..(exit,-,+,Menu).
This problem started some 2-3 months before..
Today I hav put some etylene cleaning solution through the gaps to clean from dust... still no change...
If somebody having a remedy please help me..
Sep 11, 2010 | Computers & Internet
Computer starts but touch pad not working so no pointer so cant get into contol panel or programs
You will need to boot into safe mode - by pressing the F8 key once every second during bootup until you get an option menu and select "safe mode with networking support". Once it starts your touchpad should work - then you will be able to go into your Control Panel to re-install the drivers for the touchpad - Then reboot.
The other way is to use your "Start" key (bottom left on your keyboard between the ctl and alt keys) then TAB key to your control panel - and the space key in place of a mouse click.
Good Luck
Aug 01, 2010 | Samsung R610-64G Laptop
Cant access volume control after downloading driver
If you mean the Volume icon in the system tray then you have to make it visible by Start->Control Panel->Sounds and Audio Device Properties. here you will fing an option where it says Place Volume Icon in System tray. Just click its box.
Jan 13, 2010 | Toshiba Satellite L25-S119 Notebook
Firewall setting dowload cant download
Usually the firewall settings are found in Control Panel on your computer. If you are running Windows XP, click on the Start button and select "Control Panel" from the right side of the menu. Select "Windows Firewall" (or if you are in Category view, "Security Center" then "Windows Firewall"). Under the "Exceptions" tab, if Yahoo! Messenger is not already in the list, click "Add Program", then select from the list shown. If Y! isn't shown, click "Browse", then select Y! (usually can be found under C:\Program Files\Yahoo!).
Apr 27, 2009 | Yahoo Messenger
I cant run control panel
Hi when you log-in are you logged in as a user or administrator? If you are admin and you cant see control panel on start menu you can hold the windows key and press r to get a run box then type control followed by enter. You can also get to control manager from task manager.
Hope this helps
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
Volume button
go to start menu -> control panel -> sound and audio devices. you will find volume control. or another method is just click on the volume icon which is located at the right bottom of your windows desktop.
Jun 20, 2008 | Computers & Internet
Problem with Control Panel
It sounds like theres a front panel button that has become intermittant and making contact all by itself. Sometimes when you clean the screen, the cleaner will drip down between the crt face aqnd the cabinet and make the switch in front go bad. Im not sure if this is the case in your problem but its a start. If you didnt spill anything or drip anything into the front panel then your maicroprocessor could be causeing the problem, or the 5 volts that feed the micro could be noisy ie, bad filter capacitor in the power supply. Now as im sure your aware of the hi voltage inside these sets? Its best if you dont have the training to get a pro to assist you as this hi voltage can hang around inside the set even if its unplugged. Good Luck
Jul 03, 2006 | SAMTRON 55V 15" CRT Monitor
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
