Question about Toshiba TP50H95 50" Rear Projection Television
Toshiba TP50H95 TV Won't turn on - Pete
Toshiba TP50H95 cinema series TV when turn on, will click twice and then red light next to power button will flash continously on and off. TV was working fine and is almost 10 years old.
Picture was fine and had no problem until when it was turned on there was no sound or picture.
Please let me know what to do to fix it or buy a new one.
Thanks,
Pete
  • 8 more comments
  • natchez Mar 22, 2008
    Television will not power up after shut down. There are two clicks and the red light in front blinks. Generally if i would wiggle the power cord it will correct the problem, but recently that has not helped. I suspect a problem with the power cord. Can I find a replacement for Toshiba model # tp50h95
  • john_romo Jul 02, 2008
    like petes prob. not sure if it clicked twice, but, red light at the on button blinks consistantly. now this has happaned in the past and all i did to correct it was unplug it, but this time, i had it unplugged overnight and when i plugged it back in it seemed fine, until i tryed turning it back on with the remote it started blinking again, not being able to turn it on or turn off the blinking ....
  • chase100 Jul 20, 2008
    i changed left speaker with a 12 inch speaker ,and the 125.3.15 fuse blew.i replaced fuse with a 4 amp125 volt fuse,and it also blew. do i need that specific fuse? when i turn tv on ,it turns on with no picture,no sound, and the red power button keeps flashing on,off,on off.what should i do?
    i have the same problem
  • RoundRock Aug 01, 2008
    Over last three weeks, few times the picture on my TV will pull to middle of the screen and then disappear. Just like a black hole. There were some red boarders around the disappearing picture.
    Today, when I went to turn on the TV, the relay click, red power LED came on for couple of minutes, then it start blinking at 1 flash per sec rate.
    Any idea where to start with troubleshooting this TV? I have read few comments regarding blown fuses or replacing ICs on power board.
  • Anonymous Aug 05, 2008
    My televsion has the same problem as Pete's what can I do?
  • eander5314 Aug 05, 2008
    I have the same problem as pete -- I emailed last night for assistance however, when I turned the tv on it worked -- so I really did not get the assistance last night -- my tv flashes 5 times and stops -- what can I do
  • BANDJ628 Aug 19, 2008
    I have unplugged the TV, disconnected all of the external devices, replaced the batteries in the remote.
  • Anonymous Oct 31, 2008
    me too
  • namo4 Mar 26, 2009
    SAME PROBLEM: Toshiba TP50H95 cinema series TV when turn on, will click twice and then red light next to power button will flash continously on and off.
    So what do we do? Thanks!
  • Toshiba Master
  • 8,617 Answers
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Posted on Mar 02, 2008
Have same tv 9yrs old with same problem. Replaced both convergence ic's stk392-110. TV turns on now. Still has a red color problem, but heading in the right direction.
Posted on Jul 20, 2008
I have no sound
go to menu settings and check audio on?
Jul 10, 2009 | Televison & Video
TV will not turn on
the convergence amps might need resoldered. thias is a common problem after the run for a few years
Jul 10, 2009 | Toshiba TP50H95 50" Rear Projection...
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba Cinema Series
possible regulator ic. in the power supply.
Nov 20, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 22, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Televison & Video Logo
1,110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
