Porter Cable Porter-Cable Variable Speed Random-Orbit Sander , Model #7336 Logo
Posted on Feb 24, 2010
I want to bypass variable speed control for pc
I want to bypass variable speed control for porter cable router 7529, eliminate switches on router and just plug cord into a switched outlet
3 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Feb 23, 2009
SOURCE: I need a switch for my Porter Cable Heavy Duty
You didn't specify what type but I looked at a type 7 or so and the switch number is 697452 and list is 14.00. You should be able to buy that online or I would suggest if you have an electrical supply house in your area taking that one and matching it up, there is nothing special about it other than size, BUT make sure that they get one for the proper amp draw which is listed on switch. Let me know if I can help further
Anonymous
  • 3 Answers
  • Posted on May 10, 2009
SOURCE: I have a 352VS Porter Cable sander. It started
check brushes or maybe the armiture is bad.
Anonymous
  • Posted on Jun 16, 2009
image.gifpower cord stuck in rear wheel of power sander
Porter cable scroll saw runs slow
If you bypass the speed control does it run/spin up like before?
What is gmc sierra 1993 4.3l firing order?
All chevrolet/GMC 4.3L engines from 1990 thru 1995 had the same firing order.
That would be 1 6 5 4 3 2
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
2helpful
Ouners manual for porter cable router model 7529
You can get the manual on the link below.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En%20900468.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 24, 2010 • Garden
Porter cable router turning off intermittently during job
Hello. Yes it could be the extension cord or the outlet your pluged into or the feed speed of the cut.Try slowing the forward feed speed.
builderdale
1helpful
Variable speed quit working
You would need to replace the switch, give me a model number and a location with zip code and I will try and find one locally for you, Its not that hard
Adjusting the 5 speed router for different size bits
Go to Dewaltservicenet.com and in the middle of page at bottom it will ask if you are looking for manual, type in your model number and on the next page look at the manual for the type 3 router. Hope this helps
Top Porter Cable Tools & Hardware - Others Experts
Jay Finke
Jay Finke
Kardoc
deton8 von Splosion
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
