Question about Black Box Coaxial Coax splitter
Only one working.
I have this set up so that one coax goes into my computers tv tuner and one that goes to my television but i can only get a signal on my computer do you have any idea why this could be.
    Problem Solver:
  • 14 Answers
Be sure both end is connected to the tv and the splitter. check your cable wire there should be a cut on the wire, or your TV is broke the tuner is defective.
Posted on Mar 01, 2008
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Mar 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How to set up vhs taping
Most VCRs need to be connected in a daisy chain or a splitter from your input source. (You may need a tuner with some VCRs these days; either a digital to analog converter for a VCR with an NTSC tuner or a different tuner source.)
If you have analog cable or a cable box with coax out and a VCR with an NTSC tuner, use the daisy chain method. Connect the incoming cable or the coax out from the cable box to the VCR's coax input. Then connect the VCR coax out to the TVs coax input.
For a VCR without a tuner, you'll probably find a RCA composite video line in option on the VCR. Connect your cable box or converter box composite output to the VCR composite in. For an OTA source, you'll need a splitter to send the signal to both the TV and the converter box.
Most TVs do not have a video output option.
I hope this helps.
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I cant change my VT2230-M to the tv setting. I turn it on, the power light turns blue, and then the parrots come up. then the Monitor goes blank.
I had the same problem. It appears to be due to a bad tv tuner. Turn on your computer and leave the coax unplugged. Leave it for a while (15-30 min). When you see "snow" on your screen, you will be able to use the source button to change to another input and see if you can get a signal. I am running my cable through a dvd recorder and using the AV input to watch tv. Also, my HDMI, component and RGB work fine. After thank don't try to access the TV source until you have had your tuner replaced.
Apr 12, 2011 | ViewSonic VT2230 TV
I have a Polaroid 26"
It is a bad tuner, the tuner needs changed or the tuner module and that will take care of your problem.
Dec 22, 2010 | Polaroid FLM-2634B 26 in. LCD Television
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Input coax fitting shows continuity to ground braid
There is a problem with either the cable itself or the tuner. I would suspect that there is a broken connection inside the tuner. This set should be brought to a service center unless you can solder.
Let me know what you want to do and I'll supply more info.
Dan
Jun 19, 2008 | RCA F27TF700 27" TV
TV Tuner failure after warm up
Check where the F connector is soldered inside the tuner circuitry, it may have a loose solder joint there. Also check the inside of the connector where the coax is attach, sometimes the inside conductors spreads and do not make good electrical contacts.
Good Luck.
Jan 21, 2008 | Toshiba CZ27V51 27" TV
Black Box Coaxial Coax splitter Logo
89 people viewed this question
Top Black Box Computers & Internet Experts
Johnny Massengill
Johnny Massengill
Glyn
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
