Question about Kenmore 78570 / 78571 / 78572 / 78574 / 78579 Gas Kitchen Range
Oven will not work,burners and broiler all work fine
I have a kenmore range and the oven just all of a sudden will not light,the broiler and the burners are working just fine.I have read stories from other people with similar problems and they all seem to get an answer about the igniter..where do I find the igniter,so I can at least check it out...
    President:
  • Kenmore Master
  • 2,651 Answers
Under the floor of the oven, possibly can be see by removing the bottom drawer. the ignitor is hte most common aprt to go bad in any gas oven, visually it might not even look broken though and some even appear to glow(just not strong enough to open gas valve
Posted on Mar 01, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Oven burner does not light. broiler burner and all other stove burners are good.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 09, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
My oven doesn't light
you should check your fuses located in the top of your stove
Feb 16, 2008 | GE JGBP24 Gas Kitchen Range
Gas oven problems
The oven probably uses electric start. There might be a breaker in there that popped.
Nov 30, 2007 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Apr 10, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore 78570 / 78571 / 78572 / 78574 / 78579 Gas Kitchen Range Logo
244 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
