If the power supply is a Bestec ATX-250-12e, then most likely the power supply has killed the motherboard. You will have to replace both the power supply & motherboard.
You can look at the caps on the board to see if they are bad. If the tops are bulging then they need replacement, a lot of E machines had cheap caps that didn't last long. If your good at soldering you can replace them for about 20$..
Emachines don't last long. Even though the power supply turns on it still could be bad.
It is probably the motherboard. Best to buy a new computer. Pull the hard drive from the old one and set it up as slave on the new PC so you can transfer all your old files.
I put the power box on my other emachine and it ran.I even used the other one from the working one but still nothin.g
What are caps anyways???????
Need some info, what do you mean power up but power box works? do you mean the fan is coming on in the back of computer?. Please respond with some more info.
