Question about Samsung HP-S5053 Television
Gainey image on tv
It looks like some people are having the same problem I am having with my tv. Sounds like the solution is "having the v_set and v_scan voltages reset 15vdc lower"
How do you do that?
  • tbone0306 Mar 02, 2008
    A couple of people had old post on this website saying to do that. They were also having problems with a grainy image until there tv warmed up.
  • Christa Dening
    Christa Dening May 11, 2010
    How did you find that solution?
  • 29 Answers
You have to locate the test points and the adjustors using a voltage meter and a plastic probe, only adjust the V-scan voltage + - 15 volts.
Posted on Mar 15, 2008
I want to delete my id from server
I want user donna ingram gainey to be blocked from carl gainey website.
Aug 14, 2013 | StumbleUpon Social Network
Sanyo tv color doesn't look good...it shows ghost images and is too dark. I went into tv settings to adjust the colors and brightness but that only helped a little.
Sounds like a weak output voltage transformer...the set is shot...live with it or get a new one...if it is still on warantee, call Sanyo!
Dec 27, 2012 | Televison & Video
My tv does'nt show image only makes sounds
You would first have to look inside with the set on, Look in the neck of the tube (listed here as a standard TV) to see if the filaments are lit in the picture tube or not.
Dec 23, 2012 | Apex Digital Televison & Video
My toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Aug 03, 2012 | Toshiba 40E210U 40 in. LCD TV
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
3D image on panasonic 53''
Sounds like the red and green images have shifted.
In your settings menu there should be an option for it to self adjust or manual adjust of the red and green images alignment.
Apr 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Picture is to tall. it cuts off the top of the heads
It sounds like you have the image on the perspective. If you tv is 4:3 aspect ration the video source (cable box, dvd ) must be set for a 4:3. If you have a 16:9 ratio (widescreen) the soutrce should be set to 16:9..................Nevermind, Just looked it up you this TV is 4:3.
Your TV remote will have a button to toggle/change the aspect ratios of the TV. Button could be called picture/aspect/image etc. If you have an HD cable box you need to go into the video setting and chnage the aspect ratio to match the 4:3 tv.
If you need more help, please respond with more deatils.
Jan 19, 2009 | Sanyo DS32830H 32" TV
Televison & Video Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
