Question about Mitsubishi WD-52628 52" Projection HDTV
WD 62627 TV died with no power, reset ran but when I turned it on there was no power. Just had the E2P PCB Board replaced. The problem came back after the service people left. When I turn on the TV I get a blue screen and message saying Ant 1 has no signal and tv turns off in one minute. What I found is that the Device button will not open the Device Menu so I can select the input I want. After it was repaired we had a picture and message to reset Netcommand. I had to use the TV Menu to access Netcommand. After verifying everything was connected I still had the "no signal message" and the tv shut down again. I turned it back on and this time I got the Netcommand startup menu, I again went thru the set up process but no signal and then the power on the remote stopped working. I tried the TV but after resetting it no power so I am back to before the board was repaced. Any idea what should cause the Device problem? it seems stuck on Ant 1. Could it be software? Thank you for any ideas you may have that I can pass on to the service dept. Fynis
  • vortex24 Mar 01, 2008
    No lights, I get the normal green blinking when I reset but after the reset no power. Both times it died I had the Netcommand set menu on the screen. Don't know what that has to do with anything??
    Somthing just isn't letting me open the Device menu or it isn't reading there is something there and not showing.
  • Mitsubishi Master
  • 19,396 Answers
This guy had a problem similar to yours
http://www.fixya.com/support/t387173-toshiba_57hx94_reception_problem still unsolved. It seems to be a software problem, I will try to get more information
Posted on Mar 01, 2008
  • 1 more comment
  • Ginko
    Ginko Mar 01, 2008
    It could be the logic controller behind the front panel. In this case they should remove the front panel buttons and get inside, there maybe a connector that will disconnect and disengage the front panel button assembly. Doing so should free up the logic controller so the remote contorl will function properly.
  • Ginko
    Ginko Mar 01, 2008
    Also ask them to update tv firmware, that may be also a cause.
  • Ginko
    Ginko Mar 01, 2008
    Ask them to check with a replacement remote. Sometimes faulty remote can cause similar troubles.
    best regards
    Guru:
  • 1,894 Answers
Do uyou see any pattern ot red or green lights blinkging????
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
WD-62627 dark pic, contr. and bright. @ full..newer bulb.
You could try to INITIALIZE the tv by doing the following:
1) turn on TV
2) from the remote press MENU 2,4,7,0 then ENTER
3) TV will state that is INIATIALIZING
4) press the RESET BUTTON on front of TV.
5) hopefully it's fixed.
Sep 20, 2009 | Mitsubishi WD62627 62" HDTV
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Mitsubishi DLP WD-62627 Shutting Down
I was going to say that sounds like the power side to me mate the board power board check it out before you spend any money make sure it's unplugged before you do any thing and where a earth strap ok to stop you getter a shock ok
Jul 10, 2017 | Televison & Video
Wd62825 blinking green light
if you have replaced the caps on the DM and the FMT and power supply. you can unplug the e2p. the set will run without it if it is the problem, however it will take 5 to 10 minutes to boot up so be patient.
if it boots try turning it on. the picture should look terrible because no
light engine data is getting to the dm. chances are it is not the e2p, in the over 300 of these chassis i have repaired maybe 10 had a bad e2p. most likely the chassis needs to be rebuilt. check out www.tv-techs.com
Apr 17, 2008 | Mitsubishi WD62628 62" Projection HDTV
Have two Mitsubishi WD-62627 HDTV's. One will go all black and white after unit has been on a while; shutting it off and turning it back on will correct problem for a while. The second WD-62627 has seven...
The first one sounds like one of two bad boards. If you get color here always(component input (Y Pr Pb) then it's the terminal 2 PCB, and if not it could be FMT board. Either way you would need further checks to make sure. For the other set i would need email for instructions, because of broad range of problems!
Mar 12, 2008 | Televison & Video
Mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-52628 52" Projection HDTV Logo
251 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
