N 12 pulsar missing badley gradually got worse i have a low batt . checked all vacum lines
A low battery can result in low spark and running bad.
Charge up the battery and try again.
See if one cylinder worse then others, by removing wire, one at a time, with an insulator.
Switch the wire, plug, and injector from bad cylinder with good one.
If still the same, check compression.
If not, replace wire, plugl, or injector that is bad.
You could still have systemic problem like intake manifold leak.
Try listening for hissing by using a lenght of hose to hear through.
Testimonial: "thanks for the advice ill give all that a go ta heaps "
One possibility is back pressure from a partially plugged catalytic convertor.
If that is the case, then it will be better at low RPM, and worse at high.
A popping sound could also be pre-ignition, such as low octane gasoline.
With a turbo you need to always run premium.
The turbo increases the compression ratio, and it will ignite just from the compression, just like a diesel.
ta checked all those things u said except egnition and air filter wich is attached to turbo i will check all my vaccum lines , mayb it a compression problem my boost guage for turbo isnt sitting where it normally sits it seems to indicate an air leak but i cant find it .the mis is like apop pop sound out of the exhaust cheers
can be many things sparkplugs ignition wires bad gas cloged air filter or dist cap rotor need more info
