Question about Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Uno brush not spinning
I have a Eureka Uno and I just realized the brush on the underneath isn't spinning. How can I fix it?
  • 4 more comments
  • dlchavez Mar 03, 2008
    I bought the eureka uno about 3 months ago and the brush stops spinning, and it smells like the belt is burning, i followed all the troubleshooting suggestions and still nothing. I've changed the belt, rasied the carpet level, checked to make sure nothing is caught in the rollers, what else? wonder if eureka will give me a exchange?
  • bhbwoe Apr 13, 2008
    I have the same problem. I tried adjusting the spring-loaded wheels underneath but nothing seems to solve my problem. As soon as I push the pedal, the vacuum gets too close to the ground and stops the brushes from spinning.
  • Anonymous Apr 26, 2009
    Same problem. :(
  • M. Bradshaw Apr 01, 2012
    I have a eureka UNO. I don't know if the brushes should be spinning or not when it's on. I know that I got a cord stuck at the bottom. The motor works fine but now it seems hard to push. I pulled the cord out and smelled a little smoke. Now the brushes ae not moving. Are they supposed to be spinning?
  • Anonymous Mar 17, 2014
    Eureka Uno not picking up
  • Anonymous Mar 18, 2014
    the cog that spins the brush at the head of vacume seams stripped
    President:
  • 1,673 Answers
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Posted on Mar 02, 2008
  • 701 Answers
You simply need to replace the belt. Here is a link to the belts you need for the Uno model:
Eureka Belts and Manual
Posted on May 26, 2010
Throw it away
Posted on Oct 27, 2009
Brush will not spin on the eureka airspeed gold vacuum
must be the belt
http://www.emerusa.com/eurekastyleuvacuumbeltsrepalcement.aspx
Apr 07, 2014 | Eureka Vacuums
Eureka Uno Model 2999. I need instructions on how to replace the belt.
I think you will find the free manual at this URL to be helpful
http://www.eureka.com/service/manuals/80247.pdf
Oct 13, 2010 | Eureka Uno 2998AZ Bagless Upright Vacuum
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 5902AVZ and the brushroll does not work. when i remove the belt, which is not torn nor worn out, the motor spins perfectly fine. Though when i put the brushroll back into place, it shows...
Hi and welcome to Fixya. I am Kelly.
You have correctly identified the problem as the brush roll itself.
There is a bearing under each end cap of the brush roll. You can gain access to the bearings usually by gripping the browah roll end caps and rotate the caps in opposing but loosening (ccw rt / cw left) directions.
Many times I have found that there is just a mass of hair under the end cap that functions like a brake. Clean it up really well on under BOTH end caps.
Do a spin test by putting the end caps back on (Hold it horizontal) and rotating the brush roll with your thumbs. It should spin freely.
If it feels like there is still friction then your probably going to have to take the brush roll with you down to the nearest vacuum cleaner repair / supply shop and get 2 new bearings. Most shops will install the NEW bearings for you if you have the brush roll in hand. It is a much cheaper fix than the brush roll itself.
(buy a new belt too!)
Take care
Kelly
http://www.eureka.com/servlet/ListParts?model=5902avz
Feb 10, 2010 | Eureka 5902AVZ Bagless Upright Vacuum
What type of belt does the Eureka Uno take?
Here is a link to the belts for the Eureka Uno models and a manual you can view which has instructions.
Eureka Uno Belts and Manual
Dec 15, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
CHANDE BELT
you can find out how to change the belt in the manual here that I included on page 4.
http://www.eureka.com/servlet/FindOwnersGuide
Good Luck And Please Rate FixYa!
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
How to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Dec 03, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka The Boss Smart Vac, beater bar stops turning when you use it on carpet
It is a simple fix that you need. Your belt needs to be replaced. After a period of time, the belt stretches to the point where it is still strong enough to spin the brush when you have the machine upside down to look at it, but when you put the machine down on the carpet the belt is too weak to turn the brush against the resistance of the carpet.
Most Eureka belt changes are simple to do and the belts are inexpensive.
Oct 24, 2008 | Eureka Vacuums
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka Uno 2998AZ Bagless Upright Vacuum Logo
1,631 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
