Question about Canon MultiPASS MP730 All-In-One InkJet Printer
MP730 prints all colors EXCEPT Black
We have just replaced the ink cartridges and every color EXCEPT BLACK prints.
I had the same problem. After replacing the Cyan and Black the Black would not print. I deep cleaned the cartridges about 8 times, interchanging cleaning and printing test pages. Eventually the cartridges began working properly again. I know this is not much help, but it has worked for me.
Posted on Mar 06, 2008
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
I HAVE A HP PRINTER "PHOTOSMART C5580" HOW DO I GET TO CHANGE THE DEFAULT INK. I VERY SELDOM PRINT IN COLOR, AND WOULD LIKE TO BE ABLE TO ALWAYS PRINT IN BLACK ONLY, EXCEPT WHEN I NEED TO GET COLOR AND TO...
To replace the ink cartridges
1. Make sure the HP All-in-One is turned on.
2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch.
If you are replacing the black ink cartridge, lift the latch on the far left.
If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot.
Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
6. Press down on the gray latch until it clicks into place.
7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
8. Close the ink cartridge door.
re Printing in black only - you can do this by selection this option from your application and choosing the print properties of the printer and setting to Black / Greyscale printing only.
Sep 20, 2009 | HP Office Equipment & Supplies
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printer prints wrong colors
As a guess you have the color ink cartridges in the wrong places. Take them out and run a whole bunch of head cleaning routines. I'd expect the wrong colors for a while until the incorrect ink has been flushed out.
Check your manual or setup guide for the actual order . Usually black-cyan-magenta-yellow
Jul 09, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i560s prints all colors except black
I had a similar problem and found out that you have to specify printing on plain paper. If you choose paper other than plain paper, it will make the black from other colors. Check also that all of your cartridges are seated properly. My magenta was not pushed all the way down so I got green instead of black ink when it mixed the colors to make black.
Jan 31, 2008 | Canon BubbleJet i560 InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
167 people viewed this question
old marine
old marine
