Question about Hyundai ImageQuest L17T 17" LCD Monitor
Self turn on and off
My LCD PC-TV monitor is 5 years old, it is L17T .Today someting weird happend .It started turning off and on itself.It turns on and after 2 seconds it turns off, then again after 2seconds it turns on then off and so on.Do you know if this is fixable?What should I do :( ?
  • Anonymous Jun 20, 2008
    I have exactly the same problem. When i turn the monitor on, the power LED going on and off and nothing happends on display. The power supply board is OK. The problem appears only wenn the control board is attached to power supply board dose'nt matter the LCD is connected to the control board or not.
    I've already replaced all capacitors on the control board without success. Have anybody any idea? Please help...
  • noregretr Nov 22, 2008
    I've the same problem as well, i dunno but i think its about the vga cable ill try with another cable tomorrow.because everything remains the same as past i mean when the lcd was working. and it is also imposibble to POWER OFF when its changing lights to on and off. It's like stucked.Maybe the power button of monitor is stucked who knows.
Please change i.f board if problem not solve thet means problem with lcd panel
Posted on Jan 15, 2009
Tv power cuts on power light lit no picture then Tv turns it self off, when picture appears there's waves in picture and tv turns itself back off and on with no picture just black scree
Hi Patty
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 14, 2015 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
I have a 55 Insignia tv it turned it self off and want come back on.i check the power and it want work either.
Won't not want.
Hi James,
- Flickering screen
- Dim screen
- Slow start
component failure.
May 13, 2015 | Insignia Televison & Video
RCA flat screen TV turns off by itself and won't turn back on
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | RCA L22HD41 22 LCD TV
HP 17'' L1706 LCD Monitor image shacking
shacking?
well you proved its bad.
a refurb at walfart is $50, about 1 /4th a repair bill.
most the monitors all before magic year 2010 LED year.
all of the now are dead for CCFL back lamps.
1: dim
2: FLASHING JUST LIKE HOME FLORESIENT LAMPS TO.
3: TURNS yellow
4: goes dead, but flash light played on front show data.
5: works not, not next day, repeat,(random)
all do that, ever one, unless your was parked on self for 5 to 10 years.
they all die 20,000 hours (not days , hours)
Feb 28, 2018 | HP Computers & Internet
I have a Dell 193fp monitor. It's 5 years old and is used infrequently. Today the Power button started to flash amber repepatedly while making a slight clicking noise. After turning it on and off,...
This sounds like the power capacitors are failing, which is not uncommon for a monitor of this age. You can take it to a TV repairman and get the offending capacitors replaced, however, the cost of replacement may outweigh the cost of a second hand monitor
Jan 22, 2011 | Dell E193FP 19" LCD Monitor
The screen seems to be slowly turning white.
More than likely a manufacture defect. If it is not that old; I suggest contacting the manufacturer to get it replaced. Most LCD"s have 1 year warranty, and it's certainly, not weird to see 3 years.
Jul 24, 2010 | BenQ FP71E 17" LCD Monitor
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Hyundai ImageQuest L17T 17" LCD Monitor Logo
350 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
