Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Anonymous Posted on Feb 24, 2010
Maytag MF12568AEB: Icemaker stopped working. Ran all the "service tests" and determined the icemaker is operational. I am thinking the water tube that dispenses the water into the icetray may be clogged. I understand you can use a hairdryer to melt any blockage, but I am unclear where I should direct the air. There is a hose hanging down from the ceiling of the icemaker compartment, but I don't think it's a good idea to blow the hot air directly up into the tube (to avoid electric shock). Please advise.
Mike
Level 2:
Scholar:
  • Expert 57 Answers
  • Posted on Feb 24, 2010
Mike
Expert
Level 2:
Scholar:
Answers
57
Questions
0
Helped
17491
Points
166
If you're wanting to 'melt' any blockage, direct your dryer at the point where the water supply tubing goes into the area around the icemaker. HOWEVER, there should also be a solenoid on the unit that opens to allow water to flow; that's usually the problem. Do you know if the solenoid is working? The solenoid is normally located and the bottom of the unit. The water supply line from the house feeds into it. An electric solenoid with also have a couple of wires coming from it for power. Try tapping it with a screwdriver a couple of times incase it's a little stuck. There may also be a problem with the board that control your unit's programs
Testimonial: "Thanks so much! It was indeed the Solenoid! Took it out, pressed up and down on the spring action a bit, but it back in, then heard the water fill!"
  • Mike Feb 25, 2010
    Cool beans!!!
Installed new ice maker for my MDF2561HES Maytag fridge. It has ice in it but won't dump it. Heard sizzling noise from it. What's wrong?
I think you mixed the F and the D in the model# so it should read MFD2561HES instead.
There are a few things that can cause an ice maker to stop working. Firstly, would be the temperature inside the freezer not being cold enough. It should be as close to 0' F as possible.
There is an inline fuse that sometimes, but rarely blows. When you changed the icemaker, did it come with a new harness or did you swap the one off the old icemaker onto the new one? Removing the harness and ohming the black wire ( The one with the white piece that clips onto the bottom of the icemaker) will determine if that fuse is still good. Without knowing what happened to the old icemaker, I would not rule that out!
More commonly, The water solenoid goes bad and will let the icemaker cycle without giving it water. Sometimes it goes completely dead while most often it fails to close completely. When this happens, it allows water to "drip" and usually freezes inside the water fill tube. ( Think of your kitchen faucet.. When they start to go bad, they will not shut off and needs to be jiggled to stop it from dripping) If this happens, the fill tube will need to be defrosted after a new valve has been installed. Defrosting the fridge is recommended as you can damage the inside if you use a hairdryer or some other form of rapid heat.
The sizzling sound you hear is most likely the fridge in its defrost cycle. During this time, you would not hear it running and it would get louder when the freezer drawer is opened. It would sound similar to water drops hitting a hot stove. This is completely normal and happens randomly! Do not panic over this!
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
2helpful
2answers
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
3helpful
2answers
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
2answers
Icemaker don't work
Most icemakers have their own brains so to speak all they need is power, low temp, and water to work.So check the water supply to the unit and use a test cord to check the water valve. It could be not cold enough in the freezer ,check temp and shrouds etc.
once you've ruled out outside influences you've got to dismantle the unit and check microswitches and stats all the while on the lookout for something thats broken lol
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
2helpful
Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
2answers
Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
2answers
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
