Question about Canon Sure Shot 70 Zoom Date 35mm Point and Shoot Camera
Canon Sure Shot 70 flash only partially opens.
The flash on my Canon Sure Shot 70 only partially opens. I think it was pushed down while open. Any ideas on how to fix it?
SOURCE: Canon sure shot WP-1 loads film but won't take a
Did you check the battery? It takes a 3V lithium
Posted on Sep 01, 2009
  • 1894 Answers
SOURCE: shutter cover opens partially in power shot A520
brother the camera gear system has got problems it seems. it happens due to misplacement of gears inside it.
even tough u can do it manually dont take risk of doing it manually untill u have full knowledge of internal parts. am from chenai. here in our service centre it costs around 1800 rupees for servicing it. so better take it to service centre.
Posted on Dec 23, 2007
daverh
  • 117 Answers
SOURCE: Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Posted on Jan 14, 2008
SOURCE: My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Posted on Mar 23, 2008
cpt100
  • 154 Answers
SOURCE: can't find battery compartment for canon sure shot tele
The battery cover should be on the left side of the body looking at the front of the camera next to the strap holder.
Posted on Mar 27, 2009
Howw do you rewind the film on a cannon sure shot megazoom 105
Their is a small button on the bottom you push in then rewwind the film to take it out.
Jan 25, 2013 | Canon Cannon "sure Shot" 35mm Flash Camera...
Once i fix and remove the External Canon Flash the built in flash does not work. ie the camra still thinks the external flash is fitted.
slide in the external flash in the spring block there 'a micro imterruttore that remains closed, the clip just push up real (with the help you tweezers) and the Micro will open' no longer reports' the external flash
Sep 01, 2011 | Canon EOS 550D Rebel T2i Digital Camera
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Canon ds6041 digital rebel problem with AF 70-33 mm
    Try cleaning the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
    May 31, 2010 | Canon Digital Rebel / EOS-300D Digital...
    My digital ixus 70 camera.my camera screen is black when i open my camera,snap shot is also black,plz help
    A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
    Jan 23, 2010 | Canon Cameras
    Power Shot A620 Canon 7.1 mega pixel 3 years
    Dec 30, 2009 | Canon PowerShot A620 Digital Camera
    I have an old 35mm Canon Sure Shot 70 Zoom. There is film in the camera, but the battery is dead. I can't find the owner's manual and want to know if I'll expose the film if I open the camera to change the...
    You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
    Sep 04, 2009 | Canon Sure Shot 70 Zoom Date 35mm Point...
    Black lcd screen on Ixus 70 shows icons but will not take picture
    To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
    http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
    Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
    Canon lens cover won't open
    Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
    Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
    http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
    Jun 09, 2009 | Canon PowerShot A630 Digital Camera
    Shutter cover opens partially in power shot A520
    Dec 23, 2007 | Canon PowerShot A520 Digital Camera
    Canon Sure Shot 70 Zoom Date 35mm Point and Shoot Camera Logo
    44 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
