Question about Radio Shack Cinego D-1000 Multimedia Projector
Static on S-Video Input
I've recently tried to hook up my laptop s-video output to the video-in of the Cinego D-1000. But the video on the projector is bad. I see a lot of diagonal lines. Thought it was something wrong with my laptop. So hooked another laptop. Same problem there. BTW, I never used the s-video option on my Cinego till then. What could be the issue? Thank you.
  • 53 Answers
Grrrrrr
Posted on Apr 26, 2008
Need to get a torpedo projector to work with laptop
Unfortunately, there is no simple VGA-to-RCA adapter cable if you're connecting to a composite video input (usually colored yellow) or s-video input. VGA output is separate red, green and blue video and synchronizing signals, and they all need to be combined. You need a VGA-to-video converter to do this.
If the projector has component video input jacks, then you can buy a simple adapter cable.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Radio Shack Cinego D-1000 Multimedia...
How do i connect more compponents to my projector
The projector came with three video cables, and one audio. The first of the video cables is for component (three colors, which are blue, green, red) and is used for HD (hi definition) components. The second is an S-Video cable, which is used for just that, S-Video, which is one step below HD. The last type is composite, which is used for regular input. It has one input, which is yellow.
In order to utilize more than one component, you have to have a switching device. Since it is impractical (for me, anyway) to constantly unplug one video cable on the Cinego and plug in another of a different type, you must ensure that all of your components are of the same type. You may convert somewhat between components using cable adapters, but can only do so when the conversion is one level. The levels, from highest to lowest, are thus: HD, Component, S Video, Composite. You can go from one level to another which is one above or below, but cannot jump two levels.
As one example, if you want to utilize the HD capabilities of the Cinego, and you have HD cable or satellite and also a BlueRay disc player, such as a Playstation 3, you connect your HD cable/satellite and the PS3 each to a switching device, and connect the switching device output to the component input on the Cinego. The switching device, if you buy an automatic one, will detect whether the cable box or PS3 is on, and will transmit that signal to your Cinego. You may have to use an HDMI to Component conversion cable, or your switching device may have the ability to input HDMI but output the Component. The Cinego can only input the Component, as it doesn't have the HDMI input connector. The auto switiching device is about $25 and is available at big box retailers such as WalMart. So are the cables available there.
Apr 20, 2009 | Radio Shack Cinego D-1000 Multimedia...
Connect Cinego to MacBookPro
The projector has a computer video cable input on the side of the unit. If yor MacBook has a female VGA output, simply purchase a VGA cable (double male) at a Radio Shack or WalMart, or other comparable retailer, and connect the two. The Cinego will find the input signal from the Mac, and you have to press the right keys on the Mac keyboard to tell it to put the screen signal through the VGA output on the side of the MacBook.
Apr 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Cinego connection cables
The question seems to indicate that you don't have the cables. The unit comes with three different cable for video input. One for Component (HD), one for S-Video (looks like the round plug for a mouse on a computer, but is wired differently), and one that has a single yellow plug that probably is compatible with your VCR. If you don't have the proper cables, get with your Radio Shack dealer to get the, since trying to use a cable which was not designed for the unit may cause damage.
Nov 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
SRC button on cinego projector will not read source
Three (3) things you can try:
1. Lower down the Screen resolution of your laptop as well as the Color quality and the Screen refresh rate before doing the Fn + F5. If it works, adjust thereafter;
2. Do a soft (Factory) reset of your Cinego in the in the Management Menu (credit to Cooljazz); and/or
3. it is just "slow" in sensing the presence of a VGA source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait or ...Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Connecting tv/cable box
This is a fairly common problem with this model. In most instances, it is just "slow" in sensing the presence of a video source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait.
Verify that you have done the connections correctly. Yellow RCA connector is the video while the red & white are the audio. Of course the Video input should be connected to the Video output, same goes for the audio. Please refer to pages 22 & 23 of the user's manual for more detailed instructions as well as illustrations.
A couple of things to consider: it is not HDTV capable and pls don't loose the remote.
If the unit will not select a source after some time (minutes), perhaps your best bet would be to seek replacement.
Jan 12, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego Projector to a laptop
Describe the connections available to you on the projector.
Jul 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
107 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
