Question about Brother MFC-9420CN All-In-One Laser Printer
TR Roller The error message on the display screen of my Brother MFC-9420cn says: NO TR ROLLER Install the transfer roller. I followed the instructions on the brother website to take it out and put it back in again and it still says the same thing. I have switched it on and off. Any ideas? or can anyone signpost me where to go to get a solution. Thanks keith Boyd keithboyd@gmail.com
Here is the solution for the Transfer Roller problem from brother especially the MFC-9420CN. I found it on the Brother website.
http://pub.brother.com/pub/com/pdf/no-trroller.pdf
Posted on Nov 18, 2008
    Scholar:
  • 60 Answers
Have you tried unplugging the unit for a period of time to clear the error? Or maybe the TR roller needs to be replaced. Depending on usage the roller might be misshapen & the sensor/s don't recognize that it's in place. Have you written to Brother about this problem? It may be a problem they've encountered before & they might have an easy solution or it may require sending it for repair.
Posted on Mar 01, 2008
Where is transfer roller
Transfer roller the assembly is apporx 11" long and is attached to insaid
of the rear cover
Feb 14, 2013 | Brother MFC-9420CN All-In-One Laser...
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
When ready to print paper only goes through a little and then message says paper jam..it now happens all the time
If you have had your printer for some time now it could possibly be that the feeder rollers are worn and aren't picking up the paper correctly, causing the printer to think it is jammed. The rollers don't have to be changed very often, but they do get old. A new roller kit will cost you anywhere between 30 and 50 dollars online. They are super easy to install. The only thing to make sure of is: don't order a full maintenance kit. Yes, they have the rollers, but they are most likely going to send you a fuser as well, which will triple the cost. Try to find just the rollers. The replaceable rollers are; the transfer roller, paper pick-up roller (which is probably your problem), cleaning roller, and separator pad (also one that has to do with the paper).
Aug 18, 2010 | Brother MFC-9420CN All-In-One Laser...
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
Faded Image coming from Brother 9420cn
You probably have the new roller by now.  But just incase the problem continues, clean the high voltage contact on the right side for the roller and on the drum unit itself.  If it is dirty you'll get light printing.
Nov 19, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN Transfer Roller
This web site below have the guide to replace the belt and how to reset them
http://www.simplyinked.com/support/index.php?tsrc=knowledgebase&act=117&category=C5
Oct 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother 9420cn message on display transfer roller not installed, appeared during printing session, cannot rectify
Replacing the transfer roller
1 Turn off the machine’s power switch.
2 Open the back cover of the machine.
3 Release the transfer roller lock levers on
the right and left-hand sides, and then lift
the levers to release the transfer roller.
4 Take out the transfer roller by gently
pulling the right-hand side up and sliding
the transfer roller to the right.
5 Put in the new transfer roller by holding
the lock levers of the transfer roller and
adjusting the angle of the transfer roller
lever shafts (both sides) to match the
transfer unit grooves. Put the transfer
roller onto the shafts and place the roller
onto the springs as shown below:
6 Push the lock levers down to lock the
transfer roller into place.
7 Close the back cover.
8 Turn the machine’s power switch back
on.
Apr 30, 2008 | Office Equipment & Supplies
MFC 9420cn is asking for a transfer roller?...
Open the back cover near the top. The transfer roller is part of the cover that you open.
Jan 16, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
449 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
