Question about Lexmark Color Z45 InkJet
Lexmark Z45 printer won't print
My Lexmark Z45 printer won't print. The paper feeds, and I can see the cartridge moving back and forth. The paper sits there for a couple of minutes, then the paper is fed forward a little more, protruding from the printer, but not released from the machine. I see a line of type at the very top of the page that looks like alot of strikeover print.
Any suggestions?
  • Anonymous May 26, 2008
    I'm having the same problem as what you describe. Just started on my 6 year old Z45.
I am the same user as the guest above, I just found a solution. I took mine apart. I found that (when looking at the unit from the front with the cover off with the gears on the left) the 3rd gear from the bottom left had a crack in it. It was the gear that turns the 4 large round rubber cylinders from underneath the paper. Anyway, I kept turning on/off until the crack was on top and then I dropped a drop of Super Glue (red cap version for use on Rubber/Plastic/etc.). I put a little pressure on it using 2 thin screwdrivers in the gear teath to compress it but in looking back I don't think that was necessary. I think the crack in the gear was causing mine to slip so just making it solid again helped enough to make one work like normal again. I'll see how long this holds up. Good Luck. Scott.
Posted on May 26, 2008
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Wont print in colour
Check the printer settings in "Control Panel", "Printers" are not set to "Greyscale" or "Black & White".
Sep 16, 2009 | Lexmark Color Z45 InkJet
Color Cartridge Has Stopped Working...Lexmark Z45 Printer
i think this a firmware issue of the printer..
try to flash a new compatible firmware .
May 12, 2009 | Lexmark Color Z45 InkJet
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark Color Z45 InkJet Logo
366 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
