Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony KDF50655
Occasionaly my Sony will not turn on, the lamp light blinks like the bulb has failed. But it still works, I moved it so we could use a different tv until this one is repaired, and it started working. I moved it back, same thing, a couple days later it malfunctioned again. Pulled the bulb , inspected, reinstalled, started working, Loose connection on a drive board? Bulb trying to fail? Gremlins?
    Genius:
  • 1,694 Answers
Consider the lamp door as suspect...if it warps slightly,the
safety switch is not made = three blinks......Replace door
cost about $5.00.......................................T.
Posted on Mar 05, 2008
    Champion:
  • 208 Answers
Most likely this is a bad lamp. Very common when the sony lamp is failing to get int. power off.
Posted on Mar 01, 2008
Sony projector 3LCD lamp/cover blink red
When I plug the LCD the LAMP/COVER flsh blinking red light
May 28, 2012 | Sony Office Equipment & Supplies
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
No picture
More info please. I assume you have a new Sony lamp installed? Have you closed the outer door for the lamp? When the set fails to turn on, does the front panel light blink a certain number of times? If so, how many blinks?
May 28, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
When i turn on 3lcd wega engine tv the green light blinks for about 30 secounds and the lamp light blinks continously aNd tv never comes on
change lamp.the lamp # is XL2100U THE BEST PRICE IS IN LAPTOP FOR LESS.www.laptopforless.com is complete lamp & housing $93.95
Feb 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
My sony kds50a2000 failed lastnight. Bulb only?
There could be something else that caused the lamp to fail but if it has 6 to 8 thousand hours on it that is the expected life and it is not uncommon for a lamp to fail this way.
Mar 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
