Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore ultra bake
Display reads F2E0
  • mikeyflake Mar 01, 2008
    This is mikeyflake,just solved my own problem,i pulled out the stove,mixed a coffee and triple baileys,found tech manual,pressed cancel for 5 seconds to confirm F2E0 code witch was keypad short,unpluged stove,mixed one more triple and voila woman is makin me a treat. P.S.Tech manual was taped to back of stove,good bye and good luck.
While I was reading this helpful solution for fixing the F2EO problem and then went back to try these suggestions, it magically fixed itself! It must be the luck-o-the-Irish baileys!
Thanks so much! Yolanda
P.S. I suggest that you don't clean the keypad with a vengence, especially the impossible to reach dirt that collects on the outside rim! I wish they had come up with a better design, probably wouldn't recommend this model.
Posted on Mar 27, 2008
I have a kenmore ultra bake, model #665 75022101 and the oven doesnt work the code E0-F3 comes up. i have the manual and have tried what they said to do but it doesnt work. i have bought a new sensor
The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
Taken from...
http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
Jan 12, 2012 | Ovens
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
Whirlpool Super Capicity 465 gas range. F2E0 displayed and beeping. Pressing "off" stops the beeping, but it resumes within seconds. Pressing any temperature setting, bake, on, or off had no effect. ...
Hello there:
This code is a fairly common code with these ovens
Unfortunatly the code is refering to a faulty key pad you will need to have it replaced. or repaired
Depending on your model this will cost any where from 130 to 250 dollars for the part ok?
Hope this is very helpful for you
May 30, 2010 | Ovens
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a kenmore Ultra bake selfcleaning oven super capacity. after i set it for self cleaning the display started beeping and went completely blank. please help
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Ultra Bake Oven Won't Heat Up
Turn the breakers off and wait 10 minutes and then on.  If this doesn't clear the problem, you'll need an electronic timer module.  Electrical spikes cause problems like this.
Nov 17, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore ultra bake oven is locked
The manual is located at the back of your oven. If your oven is against a wall, pull it back, not too far, and you will see a manual taped to the back of it. From there, it will provide you with answers some employers won't know. If it's not there, sorry, you're outta luck!
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Ultra Bake GAs oven
Here's a link: http://www3.sears.com/ put in your make and model and you can order a manual. Good luck!
Jul 19, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
268 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
