Question about Reddy Heater-30-55,000 BTU Variable
Reddy heater TB100 propane
Have good spark, fan runs ok, have gas but will not ignite.
    Sergeant:
  • 288 Answers
Well it sound like you have all the components working. Try lighting it with a torch or long match or something. If it lights, then you may need to adjust the spark-er. You also may need to adjust the pilot. It may be too much pressure, which will blow out the flame, or its not enough gas. Make sure the pilot orifice is clear.
Posted on Mar 06, 2008
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I have a 225,000 to 375,000 btu propane heater that the gas valve will not open on. The igniter sparks I can see that .There does not appear to be a thermocouple unless it is built into the igniter. T
YOU MAY NEED TO CLEAN THE NOZZLE, THE FUEL FILTER, & POSSIBLY ADJUST THE PRESSURE AT REAR OF UNIT. MAKE SURE THAT THE FILTERS ARE CLEAR & UNIT HAS PROPER AIR FLOW OTHERWISE IT WILL OVERHEAT & TRIP THE HIGH LIMIT
Dec 25, 2012 | Reddy Portable Forced Air Propane Heater...
I have a reddy heater pro 100 and when I start it up the fan turns but it won"t ignite. any help would be apprciated
You should be able to both see and hear the spark when this unit starts.
If you do not have spark the first thing you want to do in to clean and check the grounds on the heater.
You also need to make sure you have a good ground connection between the botton on the heater and the main section of the heater.
The spark on this unit need a good ground to complete the series and give you the spark required to start the heater.
If after you check this you can still not get spark you may need to replace the DSI Spark Controller.
Thank you
www.desaparts.com
Jan 03, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
The gas does not light
get a new unit dont play with propane it goes bang!!
Oct 31, 2009 | Reddy Heater RLP100 Portable Forced Air...
I have a 35000 btu propane reddy heater that wont ignite .
the thermocouple is bad.it needs to send a signal to the gas valve to say it's okay to stay running.replace it and the problem should go away.if not let me know
Mar 13, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dyna Glo forced air propane heater
...found out that this is a continuous ignition heater so the igniter is always on.
Sep 22, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30-55,000 BTU Variable Logo
220 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
