Question about Toshiba 65HM167 65" Projection Television
Tv will not turn on. lamp light is flashing 3 times. i put a new lamp in it and have the same problem
    New Friend:
  • 4 Answers
The boot data is corrupted. Download the firmware update from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Posted on Apr 28, 2010
  • 2 more comments
  • jinhopark Aug 20, 2011
    Toshiba has taken the firmware update down for some reason...so if someone has the zipped file and can email it to me that would be great. Thank you.
  • bigdufus Sep 21, 2011
    The update file is here
    https:rapidshare.com/files/4153045258/2007sen069.zip
    make sure you don't use an sd card larger than 2 gig or it probably
    will not work
  • lujiku
    lujiku Sep 16, 2012
    I have the same problem with my Toshiba 65hm167 tv. Can you send me those files for repair?
    New Friend:
If you have 3 yellow blinking lights,believe what bigdufuss writes...it really works...just did it myself..just make sure to unzip the folders and load the firmware to your SD card...i used a 1 gig...it will work...
Posted on Feb 10, 2012
Ur an idiot thas why. you are probably white too
Posted on Mar 08, 2010
SOURCE:
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT - 50DL54 Lamp problems
This can either be a problem with the ballast, or the power supply that powers the ballast. DLPs are usually easy to diagnose as they have a list of items that must happen for a successful boot sequence and it will pinpoint exactly where you trouble is at. I do suggest that you get a service manual for your set. I can post a link where you can get a proper service manual where they will email it to you if you would like. Let me know if I can assist you further.
Posted on Apr 08, 2008
  • 5 Answers
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
  • 68 Answers
SOURCE: turn on tv, the green lights flashes 3 times
COLOR WHEEL !!!!!!!
Posted on May 20, 2010
  • 8457 Answers
SOURCE: Just replaced a new lamp. TV tried to turn on/off
Ur tv have a Ballast board that help to ignite the lamp.U hear alot of clickings,that mean the ballast board is dead,not doing it job.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Posted on Jul 10, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Power light is flashing 3 times consecutively. When hitting the power button the fan comes on then shuts back down..then starts flashing the red light again..I've recently bought a new lamp and installed...
Put lamp cover back in its place as 3 times blinking light shows lamp cover has not been fixed.
Lamp cover is first thing that you removed to replace lamp in tv, make sure it is fixed securely in its position.
Aug 13, 2010 | Sony KDF-50E2000 50" HDTV
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
May 07, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Oct 20, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Toshiba 65HM167 65" Projection Television Logo
1,654 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
