Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Oven won't lock and self clean.
Hi, We have the Jenn-Air JDR8895AAS Dual Fuel Range. We can't get either oven to self-clean and I think it is because it is having problems locking? It won't manually lock either. We have trouble shooted through the manual and checked the "sabath" feature (not the problem). We just get a double beep when we press "clean". Note it has cleaned previously this problem just started. ?? Help!
  • Steve Masymas Apr 14, 2008
    Oven beeps twice when you press the clean key. Door can not be locked manually. Not in the sabbath mode.
    Problem Solver:
  • 15 Answers
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Posted on May 02, 2008
How do I set the cleaning cycle?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 07, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How to use self cleaning feature. I lost the manual
You just leave the oven going for a number of hours if its like my oven.
Jul 21, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Circuit breaker goes off while self cleaning
self cleaning uses above normal cooking temps
check how many amps your stove is rated for -40 amps ?
see what size breaker you have 30amp ?
call electrician
hope this helps
Mar 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Suggestions for cleaning the genn air stove top JDR8895aas
I have no solution but I have a Jenn-air stove, white with dual fuel and the oven door is badly stained on the top, probably from the vapors when self-cleaning. I have tried many things and they won't touch it. can someone help me out
Dec 14, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Uneven Temp in Ovens after Self Cleaning
in the users manual there will be a calibrating page. also self clean is hard on the oven a sensor that is meant to read 400 degrees has a hard time being accurate after 900 degrees
Dec 13, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven door during self cleaning mode
hi there sounds like a faulty door interlock!!!!
have you tried just leaving the cooker on self clean as some models will lock them selfs.
Feb 29, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-air gas electric grill range
This is not a problem. The cleaning cycle goes on for approximately 4 hours as I recall. it will unlock by itself when done. Read your user guide for troubleshooting tips. if you can't locate your copy, one is available on line at the Jenn-Air site
Nov 24, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
613 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
