Home | Blenders | Hamilton beach 4200 wat...
Blenders
Problem for Blenders
Generic problem for all Blenders
Hamilton beach 4200 water dispenser
By zgreat1 on Mar 01, 2008
Does anyone know how to disassemble this dispenser for servicing? I have removed all the screws but I can't open the unit to clean the inside and check what's making a loud whining noise when I turn on the cold water switch. Thanks.
Comments:
Mar 01, 2008
- I have to post this under "Blender" since no category for dispenser exists. Please redirect to the appropriate post if you can. Thanks.
Mar 01, 2008
- I managed to disassemble the unit after unscrewing the clamping attachment for the unit's cable. After cleaning the dust off the two fans, the unit makes less noise but does not behave like it used to be.
Clarification Request
Posted by bidme2come on Feb 08, 2009
http://www.outletpc.com/fans--cooling--case-fans-90mm.html?gclid=CKSj_vj8y5gCFQpuGgodSBwR0g
I found 90mm fans advertised at this site. Is this what you are referring to? Can an amateur fix this?
Same Problem
Dec 26, 2008
-   Had an overheating problem...
Hard time opening the case too, but with only the 5 screws that connect the two case halves (underneath) and the cord clamp screws off, with some (prying) pressure, the two lower halves popped apart. The cases halves and the top all have about a million snap locks holding them together.. I found one of the thermostats loose in its mounting, so i hope that is it... all of the rest of the screws in the bottom are to mount the hot and cold water tanks.-   rocinbaja
Nov 21, 2008
-   Water stoped coming out cold. When I felt the outside of the dispenser it was definitely warm. Didn't seem that the usual sound of the cooling unit had been heard in awhile. I've been trying to take it apart but can't seem to get inside.-   Guest
Mar 30, 2008
-   Mine did the same thing and now has a foul taste in the water...I've tried everything, cleaning, new water, I am thinking about taking it back. I love these things and even bought two for the office. I hope this isn't a trend.-   jyoeseh
Best Solution
posted on Jun 06, 2008
Very Helpful)
1tonchev
Rank: Apprentice
Rating: 100%, 3 votes
i have had this unit for 2 years and the first thing that will go out is the cooling fans, they either stop altogether or start making a loud noise. i suggest to anyone else who has this to go to a computer store and buy 2 quality 90mm fans, they will screw and connect right into the unit. mine initally died about 4 months into use and after replacing them with good fans i never had a problem with it. mine however is a dust magnet and if i dont remove the fans and clean off the heatsinks about every 3 months, the water wont get very cold. mine now is starting to leak water, a big loss since we use this thing all the time.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 28, 2008
Not Rated)
KLaM DiGGuH
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the tip! I'll give it a try.
Was this helpful?
Yes
No
Popular Solutions for Blenders
Questions and Unsolved Problems for Blenders
Answer
pour spout broken on back to basic sp smoothie 600
Answer
I have a jenn-air blender. The touch pad mounting holes are broken and it is not aligning properly... (More)
Answer
The glass container for my blender (model CP42149) fell on the floor and broke when my husband tried... (More)
Answer
i have a model r55a---it goes on for a few seconds, then shuts itself off. whats wrong
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Blenders:
Top Blender Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
