Question about Compaq Presario 1200 Notebook
When i turn on my computer, a box comes up saying: Msgsrv32 has caused an error in MMSYSTEM.DLL Msgsrv32 will now close. whar do/can I do? is my computer dead now? worth fixing?
  • 520 Answers
Just reinstall windows.if your not sure how to ask me.
your pc is certainly not dead theres just a few system 32 files missing.you have previously uninstalled something and shared files were deleted
Posted on Mar 01, 2008
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
Missing user32.dll
User32.dll errors come from issues inside Windows that involve the User32.dll file. This file contains important information regarding graphics details for objects such as dialog boxes. When there is an issue with the file, there will be problems when using other programs that use dialog boxes and other pop-up windows. Normally, a quick Windows update will solve all errors and problems.
Click the "Start" button and then "Run." This will open the "Run" window. Type in "wupdmgr". This will open Windows Update. It will now scan the computer to detect any necessary updates that are available from Microsoft. Turn on automatic updates by clicking "Start" again, followed by "All Programs," then "Windows Update." Select "Change Settings"; then select "Include recommended updates when downloading, installing, or notifying me about updates." Click "OK" and everything will be set. Windows will download the necessary update and install it to correct the User32.dll errors Hope this helps.
Jan 21, 2013 | Acer Aspire One Netbook
I've been getting an error message: sysenv.dll missing
Hi friends,
"The file sysutil.dll is missing."
"Cannot start Metamail. A required component is missing: sysutil.dll. Please install the application again."
sysutil.dll error notifications may appear while using or installing certain programs, when Windows startup or even shutdown. sysutil.dll errors are caused by situations that lead to the removal or corruption of the sysutil.dll. In some cases, those errors could indicate mostly a registry problem, a virus or malware issue.
to Fix Sysutil.dll Errors
The sysutil.dll error message could apply to any program or system that might utilize the file on any of Microsofts operating systems including Windows XP, Windows 7, Windows Vista, and Windows 2000.
You can fix a sysutil.dll error and there are many ways to do it. A registry cleaner program can help by removing invalid sysutil.dll registry entries that might be causing the DLL error. The below utility is without a doubt the best one out there at the moment.
> Click Here http://filehippo.com/download_ccleaner/
Let me know if any further clarification is required. Hope it will help! Dont forget to rate the solution!!
Dec 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
Windows XP boot after an error, it can not find the file shfolder.dll, and is included in the Windows folder. What do I do?
http://www.fix-all-dll-errors.com/shfolder.dll/
This will fix the issue without any botheration.find that dll here :)
Dec 15, 2010 | Microsoft Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Error with M3PLUGIN.DLL
Click on start
select run
in the run box type msconfig
choose startup tab
and uncheck M3PLUGIN.DLL from the startup
Jun 18, 2009 | Microsoft Windows Vista Ultimate Edition
Rundall error loadingc:\windows\system32\evnnyad.dll
Some web pages say they can fix all error messages for a price, but I have never used them. First run windows update, then search microsoft for a fixya. Yes rundill errors can cause all kinds different problems. If you can find the program causing the error uninstall or reinstall. LAST
Next run setup (backup first) fix windows. Last run reinstall windows. mysleuth
Apr 28, 2009 | HP Pavilion a620n (PC028A) PC Desktop
CAN PRINT OFF SOME THINGS FROM COMPUTER BUT NOT ALL
To resolve this problem, register the Ole32.dll file.
To do this, follow these steps:
1. Click Start, click Run, type or copy and paste the following command in the Open box, and then click OK:
Regsvr32.exe %Windir%\System32\Ole32.dll
2. In the RegSvr32 dialog box, click OK.
Jan 09, 2009 | Canon PIXMA MP470 All-in-One Printer
Dll missing
display problime
Sep 05, 2008 | Intel Motherboard
Compaq Presario 1200 Notebook Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
