Question about GE JVM1650 1000 Watts Microwave Oven
Having to constantly reset clock, and after doing so micro shuts off
Hello - We are so frustrated. Micro is only 2 yrs. old. The digital message line keeps telling us to reset the clock for no reason. When the time is reset and we set the cooking time the micro will begin to work but shuts off only after 10 sec or so. Then the "reset the clock" message comes up again. Please help! Thanks.
The Hopkins
  • elsiegirl Mar 02, 2008
    Thank you for your prompt response. We did not purchase an extended warranty because we had faith in GE products, and have decided instead of paying out the yazoo for a repair person, we shall buy a new micro from SEARS.
    Glad you're on the internet for help.
    The Hopkins
  • GE Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
Dacor micro/convection oven flickered then the power went out on it. Looked like it reset then I tried to micro something and it immediately shut down. :'( Its absolutely dead now. Is it a goner??. Its @...
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
If it's a problem with the controller / display, y
ou can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Aug 25, 2010 | Dacor DMT2420SS Microwave Oven
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
I cannot set the clock on my LG MS1949G Micro wave
After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
Jul 11, 2009 | LG LTM9000 Microwave Oven
Frigidaire Micro made an odd noise and now it does not work!
Probably due to a loose screw or clip connection where the wires connect to the outlet's terminals.
These must be tight, especially for high-current loads like microwave ovens.
Loose connections can lead to serious or dangerous overheating.
I would say the reason the microwave made it blow was that the microwave's outlet is probably fed by (daisy-chained with) the outlet that blew.
If so, this is not really a good idea.
A high-current load (microwave, freezer, fridge, etc.) should ideally be on its own breaker / fuse with no other items on the same power line.
Jan 27, 2009 | Microwave Ovens
GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE profile spacemaker micro XL1800
It sounds like your magnetron has failed.
I would put a cup or so of water in it and heat it for about 3 minutes.
Then check inside and see if you smell any electrical burning or other smell.
You should have a 5-year warranty on the magnetron.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
Apr 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Shuts off, must reset clock
Sounds like you could have a fauly control circuit. Something like when you press the pad the processor does not interpret the information correctly and resets itself. Or the power going to this circuit is being interupted. It is VERY dangerous to work inside of a microwave. So you could get an estimate from a repair shop. But those control boards are expensive. Do not attempt to repair this yourself. For your own safety.
Aug 06, 2006 | Frigidaire PLMV168 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
66 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
