Question about Proscan PS35660 TV
Proscan tv 36in
When I push on button, tv acts as if it is going to turn on. Then it cuts out, the green light flashes about three times thats it. Tv will not turn on.
  • 2 more comments
  • skudlboltz Apr 15, 2008
    well my tv had a power surge and the fuse blew so i replaced with the excact same fuse and it turned back on then about 3 days later the tv would act like it was powering up but it would click about three times and that would be it. i have the schematics but cant find the hv transmitter or ic regulater you were talking about is there a specific name to the part.
  • Anonymous May 13, 2008
    My proscan television will randomly turn itself off. The on button flashes green three times as if the set is trying to turn itself back on. Then nothing.
  • rankin2010 Oct 30, 2008
    You hit my symptons on the head. I am not a tech and not inclined to dig in. How much is a repair such as this? For a 15 year old TV, is it time to move on?
  • hbrview Apr 01, 2009
    I have a Pro Scan 36" tube TV which was purchased in 1996. It has been turning itself off from time to time for the last year. It would go off, the green on light would flash three times, then nothing. I would be able to turn it back on but it might take several tries before it would respond. Now we can't get it to turn back on at all - just the three green flashes of the on button.
    Is this an easy fix? It apprears others have the same problem. What sort of a bill might I expect from a service repair?
When i try to turn on tv the power comes on for a second then turns off
Posted on May 17, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Many problems with this unit with the HV transformer (flyback) and also a regulator ic in the power supply. Sorry, nothing easy for this type of problem. You will need a tech to diag. and repair this problem.
Posted on Mar 01, 2008
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Television won't turn on, either by remote or pushing button on t.v. itself. light just flashes. worked fine last night
The status light flashes to signal that the power source is in protected mode. This mode has been activated by the protection system of the power source this morning, when you tried for the first time to start it. It has been activated because during the night a part inside the tv has failed and has started to act as a short.
The only way to fix that is to open the tv, test the power source, identify the power rail that is down and has triggered the protection system, follow the rail and test all components that are powered by it till you find the failed one then replace it or the whole board on which is situated.
To do this requires electronics experience, if you don't have it then call someone who has it. Or take the tv to a repair shop.
Dec 29, 2010 | Proscan 32LA25Q 32 in. LCD TV
Programming comcast remote
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
Dec 08, 2009 | Proscan 32LC30S60 LCD TV
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Power button malfunction
Sounds like a faulty power supply. Consult warranty guide if its still under warranty, if not, you really need to consider calling a repair technician
Feb 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic TV
Good Day,christie511;
It sounds like the lamp is in need of replacement. You could call a service company to replace the lamp, but it is so easy to replace the lamp ones self. So, call Panasonic and order the lamp, they will send to your home with instructions.
Three screws and your home free!
Good Luck, Big Irish.
Jul 08, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
179 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
