Question about HP PSC 2210 All-In-One InkJet Printer
Double striking letters in middle of sentence
I have had my 2210 for about 5 years, works without issues, until now, recently started printing either the same letter more than once or strikes over top of another letter, if there is a graphic involved, it is also double struck . Have tried all the usual solutions without luck.
  • 234 Answers
This was one of the BEST All-In-One printer HP had ever made
Its a real fortune to still have it.
Verification of color out – happens only after keeping the unit idle for quite some time.
1. Are the cartridges out of ink – check ink levels
2. check self-test report patterns (missing lines or streaked bars)
3. Look for missing colors or ink smears.
4. Was this issue showing up because of any one single color?
5. Was it stored in a warm environment (Stored under direct sunlight?)
6. Manual Cleaning & Cleaning from Driver
Also try the steps in this below link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00043846&dlc=en&product=79499
Good Luck
Posted on Aug 29, 2008
I have an IBM Wheelwriter 6 that stopped typing in the middle of a sentence. Everything works except the piece that pushes the selected letter on the wheel the print on the page.
Get some switch cleaner from an electrical shop and spray the solenoid that strikes the wheel.
As an antique, repair would be fairly difficult if it needs parts. :>)
Jun 12, 2018 | IBM Office Equipment & Supplies
I strike letter "m" it
try to disconnect your keyboard and turn the computer off.. when you plug it back up it should have been reset.. or go to the keyboard settings in control panel and you should be able to fix it from there... when you type on a word processor does the letters do the same thing or is it only when you are printing??
Mar 15, 2011 | Computers & Internet
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Deathadder left click problem
I've had DeathAdder for about 1 year and it started to do EXACTLY what previous people described, double-click instead of single, stops firing when I hold it in QuakeLive/Counter Strike (have to press it again, etc. etc.) windows cannot be dragged because it needs to be holding left drag, never had this before. same happens on MULTIPLE machines with this mouse, tried 2 diff laptops and desktop and even mac computer....so it's must be something with the mouse not OS/Computer
Mar 16, 2009 | Razer DeathAdder RZ01-00150100-R2M1
IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Sep 22, 2008 | Lexmark Wheelwriter 3 Typewriter
I have the same problem with my jvc with the double letters and numbers how can i fix this
Did you attempt to repair your computer on your own and then started to have this problem or did this just suddenly happen? Also, can you post a picture of what you are seeing?
Aug 17, 2008 | JVC AV-48WP30 48" Rear Projection...
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Printing problem with Star Sp200
Seems like a problem with the printer head...It is usual for matrix printers and it happens due to wear and tear..You will have to get the printing head to get replaced..
Oct 27, 2007 | Star Micronics SP 2000 Matrix Printer
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Sep 07, 2007 | Epson Stylus R265 InkJet Photo Printer
HP PSC 2210 All-In-One InkJet Printer Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
