Question about Philips Magnavox 27MS343S 27" TV
Model # 9P5534C103 - Picture is minimized
When the set is first turned on, the picture is minimized and white. After 10 to 20 minutes the picture becomes full size and color is returned. When the program being viewed becomes very light in color, the picture minimizes again until the program has more color to it. What could be causing this and what can we do to fix it?
Thank you,
Petur
  • 24 Answers
There're many reasons that can cause this syptoms.Suspect voltage drop and IC Intermitent failure.If you've a schematic would help to solve the problem faster....
Regards
alan
Posted on Mar 02, 2008
Phillips Magnavox 9P5534C103 need to replace Ics
Check with TV repair.com who sells kits for most of these sets that come with all the needed parts and instructions---you might also look on You Tube who has video instructions for a lot.
This is a older set and the chips will either be on large board to left as seen from rear or to the far right side as seen from rear--the chips are soldered in STK-392-110 OR -120 CHIPS. I can give general instructions if know where they are and what number is printed on the front of them.
Oct 23, 2012 | Philips Televison & Video
Samsung FlatPanel has picture for a minute or so then turns white/light blue
Is there same problem with other input devices also? Look for any jammed buttons on the remote. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | Samsung Televison & Video
A white screen just popped up & says to set a parental code but none of the buttons on the remote work... Can't see any picture just hear it..
Did the remote function before?
Not knowing brand and MODEL number hard to advise you other than turn off and unplug set for a minute and then turn back on.
If parental code has been entered you must enter it to use set---in this case also make sure if remote for several things you have it engaged for TV and not SAT or DVD etc.
I am here to help most of the day.
Mar 14, 2012 | Samsung Televison & Video
Magnavox 9P5534C103
Its a common problem with model. Check the site www.TvRepairKits.com for a fix.
Aug 29, 2008 | Philips 9P5534C 55" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Philips-Magnavox 9P5534C103 55IN. PEAR PROJECTION
TV does not display picture on whole screen....it has three smaller colored rings with the picture inside of it
Jun 01, 2008 | Televison & Video
No picture or sound
There is really know way to determine cost. most repair shops will charge at least 100 doolars or more just to go look at the set. something in the power supply either stanby or start up circuitry would be my quess. Do you have any trouble shooting skills? Do you have the service manual?
Apr 26, 2008 | Televison & Video
BLOTCHES ON SCREEN
This may not be the problem, but the following service bulletin may be of interest:
Last Update: 1/25/2006
Document Reference/Event ID: E30094243
Model: KDSR50XBR1, KDSR60XBR1
Subject: Picture might have a slight Greenish tint.
SYMPTOMS
Under certain conditions (especially cold/ first power ON), white areas of the picture may take on a slightly greenish tint after power on until internal temperature stabilization is achieved. Typically, this disappears after approximately 10 minutes operating time, however, in certain cases (i.e. colder conditions) the set will continue to fine tune the picture longer that 10 minutes. This is in order to create optimum picture performance under nominal viewing conditions.
This is not a defect but a characteristic of the LCD panels. Be assured that the time it takes to disappear will neither lengthen nor reduce over time.
If the condition improves but reduction in effect is desired, there are customer adjustments that can minimize this condition. Please demonstrate these adjustments with the customer, to determine if these settings are acceptable. (User adjustments are supplied in Solution A)
In cases where no Uniformity improvement is achieved (after 30 minutes power on time) proceed to Solution B; Optical block
Note:
Please be aware that all Optical Blocks exhibit warm-up behavior.
Replacing an Optical Block will not eliminate or significantly reduce the time below 10 minutes.
RESOLUTION
CAUSE:
Internal temperature stabilization needed.
Solution A)
You may reduce this effect by changing some user settings as follows:
(1) Change the Color Temperature setting to Cool - (refer to page 81-82 of the instruction manual). If further reduction is desired proceed to step 2.
(2) Slightly Reduce the Green bias (only available in PRO Picture mode under Advanced video settings), then select white balance Adjustment - (refer to page 81 of the instruction manual). Example:
a. Menu, Video, Picture Mode, Pro Mode
b. Menu, Video, Advance Video, White Balance, G-Bias (Reduce several steps)
Solution B)
Replace Optical block after gaining approval from Sony Tech. line.
Jan 23, 2008 | Sony KDS-R50XBR1 50" HDTV
Philips Magnavox 27MS343S 27" TV Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
