Question about Kenwood Radio Communications
Services menu not wright
Bought a ts-570dg and found that some one has been in the service meunand changed the setings how do i get it back to factory setings
kd8hgg jr 304-855-8897 ib4@toast.net
73's thank you
I took a radio that was new and got all the info from the menu and set it just like it and it worked.
Posted on Mar 02, 2008
Factory setings
RECORD on PAPER CURRENT Printer SETTINGS AS will be lost.
IP address used FAX Settings and what ever you use.
http://www.lib.ucdavis.edu/ul/services/mfd-3300-printing.pdf
Found this procedure on internet
http://www.ehow.com/how_7376251_reset-canon-ip-3330-printer.html
Mar 14, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Tip
Code or other problem fixes fix.
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on Mar 24, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
How do i reset my sunsui 19 inch hdmi tv to factory seting because I'm getting a cloudy signal
To reset it to its factory settings, you have to enter its service mode option. Do not change any values there if there is not necessity. Select the factory mode option only. To get more details about how to enter the service mode,http://electronicshelponline.blogspot.com/ check this link. It has details about how to enter and exit service mode. After entering the service mode, and have done the settings, it is a must get out from it, by using the exit option. All procedures are given there in detail. Pull up older posts there, by the sites' left side bar.
Jun 07, 2013 | Sansui 19 in. LCD TV
I have a samsung TV that freezes temporarily.
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK
Nov 11, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
I cant unlcok my menu.
you can reset the code by #33#0000#
or*3370# or ###847#
it will work thank you enjoy your phone
May 11, 2009 | Nokia 5000 Cellular Phone
F4:2398
enter in setings->restore factory setings->tipe the password and then click ok->the phone will be reseted on setings.Thanks
Nov 12, 2008 | Sony Ericsson K550i Cellular Phone
What is the number for dlp sp46l6hx to open up service menu
the Service Menu on these TVs is accessed by pressing INFO - MENU - MUTE - POWER in quick succession when the TV is in standby. be sure you wright down all numbers before you change anything
thanks
scott
Jul 30, 2008 | Samsung Televison & Video
Rca ctc 195 series
Before anyone changes those setings you should write them down.
Apr 15, 2007 | RCA P56950 56" Rear Projection Television
Problem in operator Service
your problem should be on the settings, try to reset factory setings under the setting menu
Oct 18, 2006 | Nokia 1100
Radio Communications Logo
55 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
