Question about Kenmore 22422 Top Load Washer
Kenmore 70 Series heavy duty washing machine
Machine does not fill completely on high. It has been getting a little lower each year. Manual does not show any adjustment for water level other than the normal low/med/high on from - seems there should be an adjustment screw at the back but nothing mentioned / nothing found.
  • Anonymous Mar 22, 2008
    c bvkdfngskdbg
  • Anonymous Sep 13, 2008
    Washer fills to ~8" below top of perforated tub when on 'high'
  • 550 Answers
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Posted on Apr 29, 2008
  • AlmostBob
    AlmostBob Apr 29, 2008
    Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
    Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month
  • AlmostBob
    OOPS, you may have to flip the switch between hi-med and back to get the water to restart filling
The water will not go out the machine it will not rinse eitha
Posted on Apr 04, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
No adjusting the water level, doesn't sound like a common complaint, but replacing the water level switch sounds like only remedy
Posted on Mar 01, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer machine heavy duty 70 series
most likely a water pressure issue try adj shut off valve off slowly until noise stops if water flow not enough ckd fill screens in back of valve for sediment and trash
Apr 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
2,018 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
