Question about Edirol UA-25 External Sound System
Cant hear recording in Logic 8 with the UA25
Hi
I have recently just bought myself a Mac based set up included was the UA25. Firstly i would to say this is terrible. Signals are poor are covered in hiss. I know i am just a beginner but my skills aren't that bad!
Basically I have a problem. When i go to record Audio, it records fine and comes out fine but I cant actually hear the signal when I am recording.
So it records and when i playback I can hear what I have recorded, just when I am recording I cant hear anything.
Someone told me before that it was because i needed to check the Input monitoring box in Logic Preferences. But it is ticked and I still cant hear anything.
Trying to put an album together but it has been put on hold until I can sort this out.
PLEASE HELP!!
it is such an annoying niggly problem but when i am trying to record vocals and they cant hear themselves in the headphones they complain, ALOT.
Thanks for looking.
  • Anonymous Jul 24, 2008
    i have the same problem . but i dont get help . :S
  • Anonymous Nov 29, 2008
    yep.. same problem :(
I have the same problem plz help!
Posted on Jul 24, 2008
I have a mac and UA25 and there are no problems.
Posted on Apr 15, 2008
SOURCE:
Logic board
I just cant hear my songs, it is playing but I am not hearing anything.
Apr 04, 2013 | Apple iPod MA446LL/A MP3 Player
Hi. I recently just bought a Sony DCR-DVD602E camcorder, which records directly onto mini dvds. However, this camera isn't recognised by my computer as I have a powerpc Dual 1.8GHz G5 Mac Tower. I can't...
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Macintosh as the operating system, (and you need to click the Macintosh balloon that comes up) then DVD camcorder as the camera type.
Jan 20, 2011 | Video Cameras
Hi, I bought a Lexicon Alpha in order to use with Apple Mac (Logic). Now, my microphone is a dynamic microphone so it does not need any phantom power. When I connect the usb cable, the blue light comes...
I suspect the problem is with the software setup in your PC. Verify all the options and also verify that the AUDIO system is assigned as stereo and assigned to the Lexicon for both in and out... Also check any "PAN" control settings. There is a possibilty that the Alpha has a dead channel...
Try putting a stereo signal into the 1/4 inch jacks and see if both record... if NOT then take it for repair under warranty... I had a Lexicon Omega that had a problem myself... warranty repair...
Jan 10, 2011 | Lexicon Alpha Personal Recording Studio
User guide Absynth 4
I don't know logic but I have it working in Sonar8 - took a while!
problem I had was the ASIO rate in my Saffire 40 - then I set the MIDI-in setting in Sonar to my Yamaha and I have fantastic sounds coming out - can't hear the recordings though, I have lost the audio output ..... this is a hoot though and will be brilliant when I get it all figured.
Bob
Feb 19, 2009 | Native Instruments ABSYNTH 4 Full Version...
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Dec 26, 2008 | Lexicon Lambda Usb Desktop Recording...
My webcam has no audio
Go to Tools | Options | Audio Settings which is how the audio and microphone settings are adjusted in Skype.
Dec 23, 2008 | Logitech Quickcam Chat Webcam
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Tascam 1804 mac book pro
Could you please tell me what error message you are receiving?
Feb 07, 2008 | Tascam FW-1804 Sound Card
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
408 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Steve Allison
Steve Allison
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
