Question about Brother HL-2150N Laser Printer
Brother Printer 2150N - toner light has come on & toner is OK
I have a brother 2150N and the toner light has come on. It will not print and the toner is not empty. So, I swapped the cartridge from another brother 2150N I have and it still does not work. Both work in the other printer though?
The printer is about 5 months old. What should I do?
    New Friend:
Bought a 2150 in 2007. In 2008 toner light came on. Bought a new toner cartridge and installed. Light would not go off. Called Brother. They had us do the following:
1) Turn power off
2) Open front cover
3) Press white button (left side) 2 times and hold
4) Turn power on
5) Press white button 6 times and hold. All 3 lights should come on.
6) Close cover
7) Press blue button 3 times. Should print demo page.
We took the new cartridge out and saved it. The original is still working fine.
Posted on Jun 13, 2010
  • MJBE
    MJBE Jan 23, 2015
    Done the above procedure a couple of times but "Toner"light stays on.
SOURCE:
Drum and error light
The drum unit has exceeded its programmed life. You can either rplace teh drum unit with a new one or if the print quality is still ok and paper jams have not been a problem, you can re-set the drum counter and clear the error lights. To re-set the drum counter, open the front of the printer where you access the toner/drum then press and hold the Go button until all lights come on in turn then go off. Release the go button and close the front of the printer.
Dec 16, 2015 | Brother HL-2150N Laser Printer
OPC-Life over error. How to fixit
If the print quality is still acceptable you may be able to perform a reset on the drum counter. If print quality is bad you will need a new drum. Reset instructions at this site.
Brother HL 2150N Drum Unit Reset Instructions
May 26, 2015 | Brother HL-2150N Laser Printer
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Check toner level on brother mfc9320cw machine
On the Brother MFC-9320CW you can check the toner settings through the printer directly. Go to your printer and press the "Menu" button (located in the center, slightly under & to the left of the screen). Then arrow down and click on "6. Print Reports." Select "Ok." Then arrow down and click on "5. User Settings". Select "Ok". Press "Start" to print the report. On the last printed page will be a list of toners and the bar will show you how much toner is left. Hope this helps.
Mar 21, 2012 | Brother MFC9320CW All-In-One Printer
Hi when I turn on the Brother HL 2150N the yellow toner light stays on & I can't print
Silly question I know, is the toner new install if not could have run out.?
Would you by chance have a replacement to insert, to see if problem perstists?
May 26, 2011 | Brother HL-2150N Laser Printer
Brother Printer 2150N, toner is on and toner is Ok, but printer not working
Don't waste your time.
Uninstall printer prog, reinstall latest update from brother website.
Apr 10, 2011 | Brother HL-2150N Laser Printer
We've replaced the toner on a Brother HL-2150n with a brand new shop bought cartridge and the only thing lit is the Toner light, nothing will print. We've opened it up, shook the toner, took the toner out,...
Most Brother printers need manually reseting when either the drum or toner is replaced. Sometimes it doesn't need it and sometimes it does. Don't ask me why because I have no clue lol. What you do is open the Front Panel button that corresponds on the top with the blue botton. If you hold it from the inside of the printer until all the lights flash ontop of the pritner, then you let go and close the door. This should reset the printer. I hope this helps and I explained myself well lol
Jun 11, 2010 | Brother HL-2150N Laser Printer
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
Jun 05, 2010 | Brother HL 5250DN Laser Printer
Drum light flashing
We have just changed our drum unit but the drum light is still flashing. The printer is printing though. Any suggestions?
Apr 12, 2010 | Brother HL-2150N Laser Printer
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Feb 03, 2010 | Brother HL-2040 Laser Printer
Brother HL-2150N Laser Printer Logo
2,179 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
