Question about Panasonic SA-HE75 Receiver
Negative volume Panasonic SA-HE75
When turning the volume up, it goes from minus 85 to zero.
Without any sound, off course.
Any suggestion ?
John
  • 4 more comments
  • Boechi Mar 01, 2008
    What battery ? I unplugged it and put it back. No use.
    Thx for reacting
    J
    The max volume now is zero.
    Indeed, the unit was and is hot.
    Greetings to you, Pincer
    J
  • Boechi Mar 02, 2008
    Hi Ginko and Pincer,
    I tried that and that and that allready and nope and nope and also nope.
    No error code on screen.
    " sytem operating correctly "
    Anyway, it's nice and quiet around the house.
    If the family insists, I'll take the damn thing to a mecanic.
    Thx fer trying
    J
    Experts until now, came with real good suggestions. Most of them I tried allready.
    Reset, unplug, etc
    When turning on the tuner/ampl, a message appears : "speakers off now "
    After pressing the speakers button: "system operating correctly now "
    But still negative sound
  • Boechi Mar 03, 2008
    Hello sweet rascal,
    First : if there was something wrong with the speakers, that doesn't explain the negative sound
    Second : if there was something wrong with the speakers , they would go one by one and that didn't happen.
    You also have a good day
    J
  • Boechi Mar 10, 2008
    That's good reasoning, micromaster !
    Only thing, if the IC or whatever has melted,
    that still does'nt explain the negative sound indication.
    If heat was the problem, the sound would just go, with or without an error-code.
    But negative sound is ** sound so the problem must be a programming/resetting one.
    You could be right but that would go against logic.
    Saludos
    J
    Brigadier General:
  • 3,614 Answers
It's usually happen when the unit is overheating the malfunction on the device is always there. The parts inside or the what we call the resistor / transistor / IC / are the one affected when the unit get warm, the parts can be cook for that instant heat and no exhaust of the hot air inside to put outside..
Only one parts have cook or melted or got the problem due to device overheating, you probably got the best of both world that your device will malfunction and soon be a dead set one.
Cheers!
Posted on Mar 09, 2008
    Guru:
  • 1,894 Answers
Hello sir
Posted on Mar 02, 2008
  • 1 more comment
  • dewan nafees ahmed Mar 02, 2008
    had you done all the settings check?
    hello sir,
    check the settings first
    since the amplifier is telling that the speakers is OFF then make sure the speakers are working fine by using it with some other amplifier.
    now you will have sorterd out where the exact problem lies right??
    tell me what is the problem
    with out sorting out the problem clearing it is very difficult sir
    hop you cooperate
    thank you sir
    good luck
    have a good day
    dont forget to rate the solutions
  • dewan nafees ahmed Mar 03, 2008
    ok fine then your amplifier is showing the error and the speakers are free from errors.
    then try a different amplifier and check what is happening.
    if amplifier is making problem then do a full service of the amplifier and check it for any shorting.
    this will help you clear it.
    thank you
    good luck
    Master:
  • 377 Answers
What the max volume?
Posted on Mar 01, 2008
  • 2 more comments
  • pincer
    pincer Mar 01, 2008
    Have you ever touch the player? I think there's a possibility that the unit is Overheating.
  • pincer
    pincer Mar 02, 2008
    Increase the airflow over the thing by getting it up off the floor put some blower on it, or if you're not feeling like making a trapeze act out out of the thing, stick it on an open box so it can better emanate heat. Apparently this has been doing some good, but hey, remember that if it can't sit on the ground as intended, it's defective, so make sure you call 'em a service man up and get it sorted!
  • pincer
    pincer Mar 04, 2008
  • pincer
    pincer Mar 04, 2008
  • Panasonic Master
  • 19,396 Answers
Try first removing battery and putting it back, so to reset the unit
  • Ginko
    Ginko Mar 02, 2008
    I was referring to remote battery, just in case it was stuck remote problem,. It is weird, because if it was overheating you should get E70 message on the screen. Try using the reset button at lower left hand corner wtching device from front. Let me know if it works, in case change my rating immediately!
    cheers
  • Ginko
    Ginko Mar 02, 2008
    Let me also know if you get an error code on screen (E and some number or 'OVERLOAD' on screen. Try also checking if you get same problem with all inputs unplugged. in this case you need to change your connections (you should have the overload message in this case). Here is operation manual from Panasonic. Follow reset procedure at pag.12. Let me know if it works.
    Best regards
  • 796 Answers
The ic controlling the volume must be faulty
My panasonic dvd stereo system sa-pm91d when the volume is turned above 25, it plays distorted sound, it sounds like I have incorrectly tuned a radio channel even when using the auxiliary input
Hi Gusma,
If you have Distorted sound.
    These may be the causes of the problem:
  • Make sure the speakers wires are properly connected.Check the color codes, be sure they are rightfully followed.
  • - Shorting (bare wires touching) of positive and negative speaker wires.
  • - Using speakers with an impedance lower than that rated for this unit.
  • - Straining of the speakers through excessive volume or power.
  • - Using the unit in a hot environment without proper ventilation.
I am also including a link to the User Manual. Read it thoroughly.
Best of Luck,
JP
Panasonic SC PM91D Operating Instructions Manual
Jun 26, 2015 | Panasonic Audio Players & Recorders
My plasma has lost volume, picture OK, turns on but not to standby and none of the buttons or remote changes anything?
First is to remove power from set and a box if used--the sound issue happened at same time? It sounds like the set locked up internally and if unplugging things does not help it may be a main board issue in the set.
Nov 05, 2012 | Televison & Video
2004 Navigator; when you turn volume control on the radio to the left; the sound goes up louder.
Hi Russel, This is just a suggestion. Is the preset maybe on ballence instead of volume? Regards john
Mar 29, 2012 | 2004 Lincoln Navigator
No audio or sound coming from speakers ,I tried all speakers oulets an nada zero
Hi William,
  1. Make sure that the muting is not on.
  2. Please press "speakers" button under the power on button to ensure that the speakers settings are not turn off.
  3. You have to select the right input and make sure that the input selected are turned on and working such as DVD, VCR, TV, etc. to isolate them from fault. Used another cable as much as possible.
  4. If still no sound, the fault is inside the unit and most likely faulty sound output IC. May I know if the unit seems working fine except from the audio problem. Also, please let me know if you are handy in electronics, have a multimeter and necessary tools for troubleshooting?
Kind Regards,
Jdvillanueva
Nov 25, 2011 | Panasonic SA-HE75 Receiver
Minute timer is not loud enough. It was but now volume low.
Set the timer to 1 minute and then press the minus button to zero it.
This makes the timer 'beep'.
If it is quiet, press the minus button again and the volume of the beep will alter, running through 3 settings - loud, medium and quiet.
Jun 04, 2011 | Rangemaster 90D Range
My 19in lcd hdtv emerson wont stop turning the volume down by its self.And then i took my batteries out of the remote and it is still doing the same thing. i cant even press buttons on the remote. Also...
See if the minus volume button on the TV is stuck. With the TV off press the various buttons while keeping your ears close to them. Each will produce a distinct click when you press them, confirm if the volume - key also produces the same sound - if not the key is defective or stuck.
Jun 02, 2011 | Emerson LC320EM8 32 in. LCD TV
How do i turn my keypad sound off on my corby pro without turning off my ringer
Go to settings-> phone profiles and tap on the [>>] icon next to the profile for which you want to make keypad silent (for eg:- normal). from the drop down menu at top right, select phone sounds. Scroll down till you see 'phone sound volume'. Reduce it to zero. Done!!
Apr 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Volume goes to zero and protection light comes on, any idea what the problem is?
Check the speaker wires for a short. Try operating the amp without the speaker wires hooked up.
Feb 27, 2011 | Cambridge Audio Azur 540A Amplifier
I have a panasonic home theatre model sa-ht900. everything plays fine but i have absolutely no sound at all.possible solutions?
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
≥Check the connections.
≥Turn the volume up.
≥Turn muting off.
≥Switch off the unit, determine and correct the cause, then switch the unit on.
Causes include:
-Shorting (bare wires touching) of positive and negative speaker wires.
-Using speakers with an impedance lower than that rated for this unit.
-Straining of the speakers through excessive volume or power.
-Using the unit in a hot environment without proper ventilation.
Jan 30, 2011 | Panasonic Home Theater System System
Panasonic SA-HE75 Receiver Logo
655 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
