Question about GPS
I have a nuvi 200 that wont run when it is hooked up to a power supply
My nuvi 200 works great but the rechargeable battery only lasts an average of 5 hours. When I go to plug it in with the car charger and continue to navigate, it holds me on the charge screen and I am unable to navigate anymore. I have the same problem if I try to use it when it is plugged directly into the wall socket in my home, the charging screen comes up and I cannot get the unti to acquire sattelites or otherwise work until I unplug it, and then its fine?
I am using the same car charger that came with the unit and it was allowing me to navigate AND charge. Now I can only charge because the unit thinks it is plugged into a computer and therefore won't charge....
  • 2 more comments
  • garydean0628 Jul 17, 2008
    same problem
  • VikingsOoden Oct 23, 2008
    I have a 255w Garmin will not navigate when in charge mode what is wrong
  • princev911 Jan 13, 2009
    mine does this too, I'm using the original car adapter, no splitters or anything.
  • Anonymous Mar 25, 2009
    Similar problem with 200W.
    Now sorted. That's rather clever. Worked for me, in that it allows you to charge in the car using a regular non-Garmin usb charger!
Vehicle Power Cable to the nüvi and connect the otI have a nuvi 200 that wont run when it is hooked  - chapin.screen1.jpgher end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart chapin.screen2.jpg(reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging."
Posted on Mar 15, 2009
  • Bob Stone Aug 03, 2013
    Thanks dodge03. Your solution works nicely, but I think you'd agree that it is a pain in the neck to have to boot the numi this way. Have you found any car chargers that will work with a USB A to USB B cable without having to enter the test mode? One would think that someone (Garmin doesn't seem to) would make a cigarette-lighter style plug having USB A outputs that would mimic Garmin's cigarette plug style charger.
2 Suggested Answers
  • 504 Answers
SOURCE: I have a nuvi 200 that wont run when it is hooked up to a power supply
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Posted on Feb 21, 2008
Why wont my lithium ion led spotlight hold a charge
I would assume your battery is no good
They last 4 years on average, I would guess
Sep 30, 2014 | Black and Decker USA Black & Decker...
Wont power up
The nuvi 200W is an older unit and it may be possible that the battery has run it's life out.
The average life span of a GPS battery is 2-3 years and possibly a bit longer depending on different factors such as climatic conditions, amount of usage, etc.
Nov 23, 2011 | Garmin nuvi 200W GPS Receiver
I have lost the ac adapter for my Xantrex Powerpack 200 Plus. Where can I get one for a reasonable price?
You need a 12 Volt AC/ 1 AMP (1000ma) charger. You can use one with a lower ma rating but it will take longer to charge. The factory unit will take 35 hours to fully recharge a totally discharged battery. If you use your car's cigarette lighter it will take 3 hours if you're charging and driving. Good Luck!
Aug 24, 2011 | Xantrex Technology XPower Powerpack 200...
My sons Dell Vostro 1500 has a problem with the AC adaptor. It will run the laptop but wont charge the battery. Any help will be appreciated. Thanks,David
If it will run off the AC Adapter but won't charge the battery then odds are it is the battery that won't take the charge and not the AC Adapter's inability to charge anything.
Google "dell vostro1500 battery" and change to shopping. You will see many available knock off battery's starting at 20 dollars.
Although AC Adapters go out too. They last a lot longer than batteries do. Today's batteries just don't last. I would say average life span is a year to a year and a half.
Jan 28, 2011 | Dell POWER SUPPLY Power Supply
My 2 yr old Garmin nuvi 200 was working fine...when I got home and turned the car off, it quit working and won't turn back on. I keep it plugged into the lighter, so it's not battery power.
No it's not the battery power: your nuvi has suffered the firmware equivalent of a stroke.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 18, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My Garvin nuvi 200 has just stopped working. I cannot turn it on. Is there an onboard battery? Is the power button locked?
yes it has a on board battery. Check to see if the plug on the back of the unit is loose. If its not thats good "kind of" the unit won't work without a charge even hooked up to power. The battery may need to be replaced. They run about 15$ on E-bay
Feb 23, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi gps navigator
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 04, 2010 | Garmin nuvi 200W GPS Receiver
Olympus e10 problem. Even with new batteries, could only take a couple of shots before the low battery icon came up & camera shut down. Would work fine using mains supply. Fixed by buying new battery...
You didn't say what type of batteries you are using. Best are CR-V3 lithium which should give 500 shots. 2300 mAh Ni-MH rechargeable batteries should give 200 shots. Worst are alkalines which Olympus do not recommend.
Have you checked the contacts in the bottom of the battery chamber for cleanliness?
Aug 14, 2008 | Olympus Cameras
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
Batteries
The Lithium batteries that are provided with the camera will supply approximately 200 images. The Ni-MH batteries will provide approximate 100 shots per charge. The B-10LPB Lithium Polymer battery will allow 500 - 700 shots per charge and can be recharged approximately 500 times. B-12LPB Lithium Polymer Battery will deliver twice the power allowing 1000- 1400 shots per charge and can be recharged approximately 500 times. The Alkaline batteries, although can be used, is not recommended due to very low battery life.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
GPS Logo
896 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
