Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
F9 code Our Jenn-Air SVE47100 keeps giving us a code of f9. I can't find a reference to this code anywhere. The house was built in 2000, not sure age of unit. Thanks for any help you can offer.
    President:
  • Jenn-Air Master
  • 2,651 Answers
Says F9, is a problem with door lock saftey circuit. replace power relay board
Posted on Mar 03, 2008
I have a JennAire model # SVE47100W with an F9 message. What do I do?
Hi
Thanks for using FixYa. Error F9 in your Jenn Air means door lock safety circuit on the power relay board sensed and to resolve this issue you’ll have to replace the power relay board. Also you’ll have to check the door latch and replace the door latch and/or assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 20, 2010 | Jenn-Air SVE47100 Slide-In Electric...
F1 fault code? Jenn-Air SVE47100
HI. This is concerning the relay board that is installed in your unit. I would recommend to inspect the entire wiring harness that is linking the relay board to the elements, and other power component's. If the harness is ok, and connected tightly, and correctly, this will confirm that the relay board has failed. It must be replaced in the case. Be sure to inspect all wiring harness connections for corrosion before you replace the board. This could be as simple as a failed connection.
PRB Part Number is #71002144
Nov 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
What does F9 mean? Won't allow me to use the oven
F9 -It is a Door latch fault code
Check door latch components.The stove is not detecting a proper door close.Or else there might be some metal blocking the door from closing.It should solve itself in few hours else you might have to replace the door latch system.Good luck with the machine.Please do post comments.Also do rate the solution.Thank you in advance.
Apr 10, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air downdraft blower doesn't work
thiknin thats a sealed unit, however imn sure they got it into a housing so i guess if you lloked close enough ther ewpuild be a few screws to gain access to the fan itself and with it open a quailty degreaser should work wonders in cleaning it!
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
I just got this Jenn Air...bought it 2nd hand in a store..how old is it?
Have a look through this lot, there are a few problems for your model discussed, but nothing that sounds like a known problem for the model; http://www.applianceblog.com/mainforums/archive/index.php/f-64.html This link has a good description of a common problem with the model (temperature too low compared to the digital readout) and it's solution; http://applianceguru.com/forum1/955.html this link has a good collection of reviews on the stove - people were still buying them new in '98, couldn't find exactly when they started selling them; http://www.epinions.com/hmgd-Ranges-Jenn-Electric-Jenn-Air_Slide-In_30-Inch_Electric_Range_SVE47100/display_~reviews If you have any problems and need parts, there are still many companies offering them online for this model - just type "jenn air SVE47100 parts" into google and you will get a good selection. Sorry I had no luck finding a user manual online, free or otherwise, you could try contacting jenn air direct to see if they could send you one; http://www.jennair.com/content.jsp?name=contact_us Hope this helps :)
Jul 06, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Beeping noise - letters appear fc
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
632 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
