Question about Hoover F5906-900 Upright Steam Vacuum
Hoover steam vac
The float on the catch bucket engages without any warer,or when I turn on the machine.
  • hugh Mct Mar 03, 2008
    Thank you very much It solved My problem immeaditly.
  • Anonymous May 25, 2009
    I am having the same problem. The vacuum is not picking up the water. I checked the filter and the float is ok. What do I do???? Help
    President:
  • 1,673 Answers
The foam filter is up too high, it is on the bottom side of the lid. Leave about a 1/4 in gap, then it should work ok again.
Posted on Mar 02, 2008
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
Manual for Hoover Steam VAc model #6040-900
need manual for steam vac dual V model:F7206-900 series:Z12.0
Jul 13, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I only used it once or twice and then the suction stopped and I can't figure out what went wrong. Hoover Steam Vac
This model has suction as soon as you turn on the machine. make sure the lower tank lid is on properly and the tank is latched in place. check the hose attachment door if that may be open. There is a float in the tank that will stop suction whenit is time to change the water, make sure the tank is empty.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Aug 06, 2009 | Hoover F7431-900 SteamVac Vacuum
Loss of suction
Make sure the recovery tank lid is on correctly. Also make sure the float on the receovery tank lid is down.
May 24, 2009 | Hoover F7431-900 SteamVac Vacuum
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Cleaning steam vac
There are screws on the bottom to remove, then near the back on each side, the is a catch to release. Before you turn it over, there is a screw where the water intake is near the top to remove.
Feb 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Valve stem assembly
Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
Dec 29, 2007 | Vacuums
Hoover F5906-900 Steam Vac
Make sure that that the lid for the dirty water tank is locked on to the bucket, the other is make sure that the filter on the inside of the lid is not all the way up, needs to be a gap 1/4 inch or so.
Aug 19, 2007 | Hoover F5906-900 Upright Steam Vacuum
HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
Jun 16, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5906-900 Upright Steam Vacuum Logo
44 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
