Question about Frigidaire ATF6000ES Front Load Washer
Whites are turning grey
I have a front loading Frigidaire washer-all my whites have turned grey-I was told I was using too mush soap-reduced soap-whites are still turning grey-not very happy
  • yetta1 Mar 10, 2008
    I have stackable front loader which I love except for the gray whites I now have. Our water heater is 145 and we have great well water. I have always been so proud of sheets and husbands t shirts, now I try to hide them. I use hc exactly how they tell, rinse twice in vinegar. also have used clorox to no avail, what else can I do. I am ashamed to hang clothes on the line thank you rosedale!@aol.com
    President:
  • Frigidaire Master
  • 2,651 Answers
, make surer your using an HE detergent, Liquid better then powder. . they just placed a product on the market in the last few months . AFFRESH tabs, found at major appliance chains, specifically designed for cleaning out theese machines.
Posted on Mar 01, 2008
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer quits during cycle
That is a SUDS LOCK. Open the front panel to access the drain pump filter. Clean it out. Run several cycles without any detergent to clear out the soap being retained in the washer. If you are not using H.E. soap, switch to it. Use the amount of detergent specified on the package. Front load machines will not work correctly with excessive soap and the laundry gets no cleaner with more soap.Also use high water levels not medium or low. Use hot water whenever possible to reduce the suds residue.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error Message
what is the error message ?
machne can lock on to mush soap
May 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Drum bearing. fwt645rhs0
Bearings failure in these machines is mainly caused by over soap use and use of non HE soap.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a front loading washer and it was flashing an error code "EFO' What does that mean?
I just spoke with customer support for my Affinity. They told me it was over sudsing (sp?). from using too much soap or not using high efficiency soap. Suggested running thru a cycle without soap to clear things out.
Aug 09, 2008 | Frigidaire Affinity ATF7000E Front Load...
LG washer (WM0532HW) whites turning dingy grey
I too have a front load washer. The problem is that it's not washing off all the soap suds. Try this. After a complete cycle, soak the clean clothes in a container w/ water and you'll see there's still soap suds coming out of the clothes. I tried running it several wash cycles and there was still soap left on the clothes. I think, it's mfg defect. We should all complain to the maker of the machines.
Jul 25, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
201 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
