Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Gwl 10 washer
Machine stopped after wash cycle and will not drain the drum will spin but nothing happens Had heard noises in draining cycle for several days prior, but they stopped
  • Anonymous Mar 30, 2014
    washer stops after the wash cycle with a smell
    Sergeant:
  • 351 Answers
Check that the pump isnt blocked.
Posted on Mar 02, 2008
My washer went through the wash cycle and into the rinse cycle and just stopped at the drain/spin part. When I pull the knob on there is a buzzing noise for about 10 to 15 seconds and then nothing. I...
I would call a local appliance store that sells and does repairs. Explain what's happening. They will probably be able to tell you if it needs service, and what type of problem it has.
Feb 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine won't drain or finish cycle
It sounds like you have a drain pump stopped up or failed. Do you hear any noise when it is supposed to be draining? A humm or buzz?
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
My BWD 129 washer dryer is not spinning or draining
I have a similar problem - washer wouldn't spin or drain. The problem with my Kenmore 90 series is that the lid switch needs to be replaced. It's a safety feature. During normal operation when the washer is spinning or draining - and you open the lid - the lid switch sensor knows that the lid is opened and then "stops" the machine. A new lid switch needs to be installed. I have picked up the part, but am still trying to figure out "how" to get inside of the washer. The only difference between what you describe, and my problem, is that there is no "unusual" noise coming from the machine. Hope this helps lead you in a good direction. Another good site is Bob Villa's site.
Jan 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Washing Machines Logo
243 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
