Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic Rear Projection TV - PT-47WXC43G Convergence Problem
I can't adjust the convergence on my tv. The picture is very distorted and there is alot of red color in the picture. I took the back cover off and covered the Red CRT and the picture quality looks alot better but minus some of the color. Should I replace the Red CRT myself or have it tested and repaired by a TV repair shop? Any advice would be helpful.
email me at: jeaux68@sbcglobal.net
Thanks
Joey
  • Joey Arceneaux Mar 19, 2008
    I replaced both the STK 392-110 IC's and checked the adjacent resistors. The resistors were all within tolerance but when I turn on the TV it powered up momentarily then shutdown on its own. The power light is blinking. What should I check next?
  • rescuehero Jan 14, 2009
    I have the same problem, I replaced the convergence amps on my PT-51HX41E -- STK392-150s. This fixed the convergence problems, and the picture looks great but, it shuts off after about 20 minutes. I hit the power button on the remote and it blinks 3 times. If I let the tv cool down, unplug it from the wall and plug it in again, I get about another 20 minutes.
    I've tried resoldering the ICs but I have the same problem.
    Did you find a solution to yours ? Or does anyone have any ideas on what the problem could be ?
    Thanks
    Scholar:
  • 133 Answers
The tube should be ok its the IC's regulating the convergence is your problem . A tv repairman should be able to repair it fro around $250.00 - $300.00 or less depending on who you call. Good luck
Posted on Mar 01, 2008
Solution # 2 is correct. I had the same exact problem and did a lot of reading on regulating of the convergence. I fixed it myself though. When you turn the tv on go to convergence 1 and when the green is on the screen make sure this is centered like a + sign. Then exit the menu, you must wait about a half hour. Hopefully your tv will stay on this time, it did for me. Then go back into setup convenience 1 and don't mess with the green cross anymore hit the action key and go to the red and blue to match up with the green. Then go to convergence 2 and fix the red and blue crosses to match up with the green to make them white. Hopefully this solves your problem it did for me a 41 year old mom. All these websites on telling how to fix the stk's forget to tell you not to mess with the green big plus sign. I read in the manual where it says never mess with this in convergence1. Anyways hope it works for you!!
Posted on Nov 13, 2009
    Sergeant:
    Champion:
  • 250 Answers
It's either your Convergence IC's or the Resistors associated with them. Here is a good write up on how to fix it and pictures to compare your problem to. BE CAREFULL! TV's carry A LOT OF POWER, and can KILL YOU. It's can be fixed by someone that has never done this before, but read read read about TV safety first.
If you got it fixed by a pro. expect to pay around $400.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Rear projection - convex distortion / ghosting / expanding screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WXC43G green convergence no longer in alignment...
you can get the following repair kit at the following link. which contains the parts and the CD which has the instructions on how to do the repair. The kit you need is called the PT-53WX53G, PT-56WX53G, PT-
47WX53G, PT-47wx33G, PT-47WXC43G
and PT4743G. Convergence repair kit its at the following link.
http://www.tvrepairworld.com/
Jul 15, 2009 | Televison & Video
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Picture suddenly distorted, green and violet lines
It is convergence out ICs failure problem and you need to replace two ICs in convergence board/ section in TV.
If you are not familiar with TV repair then call qualified TV tech to fix it.
Apr 15, 2009 | Panasonic PT-47WX49 47" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
*Screen Looks 3-D
*Colors wont align
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-60LC14 Convergence Issue
*Screen Looks 3-D
*Colors wont align
Nov 06, 2008 | Panasonic PT-60LC14 60" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to ptscorp.com
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Pt 53wx53 convergence
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Dec 16, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
850 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
