Question about Kenmore 62622 Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
Somehow my kenmore elite microwave oven became "Locked." This is displayed above the time, which seems to still be keeping time. However, nothing else works, except the door will open.
The light below the oven is on, but can't be turned off. None of the buttons respond to being pushed.
Can anyone help?
  • penn59 Mar 03, 2008
    We have had two Kenmore microwaves in the last month, because both of them operate as you describe. The first one worked for 4 months then started having the locked problem. The new one worked for 2 days before developing this same issue.
    we went to Kenmore because the Panasonic microwave we'd been buying (2) up and died after 18 months.
  • Anonymous Mar 27, 2008
    same problem
    anyone know the cost for a new keypad?
    model 721.62622200
    thanks
    tom
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Posted on Dec 17, 2008
  • Kenmore Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't work, please reply back with your exact model number.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
You may have a bad keypad due to moisture from steam or spray.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 07, 2008
  • Maryann123 Aug 10, 2011
    great site. Im not sure if I have fixed the problem but It gives me somewhere to start! thank you
    New Friend:
  • 3 Answers
You can also check on http://bakingreview.com I'm sure you will find the solutions! Top Brand Microwave Ovens Reviews BakingReview com
Posted on Jun 29, 2016
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
The display screen on my Kenmore Elite Microwave model #721.80802400 has frozen on 13 seconds! does not respond to turning or pushing dial. Only works by pushing manual. No idea about cook times. Is this...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may be a controller issue which can be repaired.
Feb 25, 2011 | Kenmore 80809 Microwave Oven
Kenmore Elite 363.63679201 Display reads Demo Mode; how do you get rid of it. Unit seems to function, but doesn't heat anything.
Press & hold POWER for 10 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 27, 2010 | Kenmore 63672 Convection/Microwave Oven
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Display needs to be replaced on a kenmore elite microwave
Try managemyhome.com. I have a Kenmore Elite convection microwave and found the manual.
Jul 03, 2009 | Sharp R-1750 Microwave Oven
Kenmore elite microwave displays F9 after a few seconds
I have the same problem. The sears guy told me that I needed a phillips screw driver and a torx adapter/driver to remove the entire microwave cover ( it slides off0 to gain acess to remove and replace the bulb.
Dec 29, 2008 | Kenmore 63792 Microwave Oven
Kenmore Microwave 62622 display says "locked" and will not operate
hold your finger on the locked button till the light goes out
Jul 04, 2008 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
1,676 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
