Question about DeLonghi TRD0715T Oil Filled Radiator Heater
Delonghi 5 fin 700/800/1500w, oil filled heater.
My son has had this heater for a few years but only recently used for an extended period of time. It was placed in his watertank holding area, so the water and pipes would not freeze. Was in use for four months. Went into check fluid on the ground, thought it was water, checked everything. It was not. The heater had lost its oil and was leaking on the floor. Question is would this cause a fire in the building. A smoke detector is in the area but cannot hear it in the log house. Has anyone else had problems with these oil filled types of heaters leaking. Can they be refilled or would you want to refill one that may cause a fire.
  • vamelanie Mar 13, 2009
    i have the same leaky problem. is it toxic to cats?
    Sergeant:
  • 288 Answers
It sounds like you have a lemon. The heat exchanger tube has developed a hole somewhere. These things are designed for the small element inside to heat up the oil, and that is supposed to radiate the heat. It would be dangerous to use without any kind of oil. The element would burn out hopefully before it started a fire, but not necessarily. I don't know what kind of oil they use, but its a thin viscosity, like some turbine oil. You can patch the hole and try some pump oil or something, but I personally don't think its a good idea. I wouldn't do it.
Posted on Mar 05, 2008
Just stop working.. one year old
It should still be in warranty, even if it is slightly past the 12 month period a phone call to the supplier might bring a pleasant surprise. It really should have lasted longer
May 27, 2015 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Where do I get wheel set for my 14 fins heaterthey are very weak plastic wheels, the hinge part.
Try places like Home Depot, Lowes, Harbor Freight, etc. They stock a variet of wheels and casters.
May 05, 2014 | DeLonghi 6707E Oil Filled Radiator Heater
The main switch has 2 buttons but only one lights up and the heater does not warm as well as it used to. It is a 14 fin oil filled heater.do I need to replace the whole unit or can it be fixed safely?
IF I REMEMBER RIGHT , THESE USED WATER HEATER ELEMENT THAT CAN BE PURCHASED AT HOME DEPOT AROUND 15 BUCKS.. UN PLUG AND REMOVE SIDE COVER .. LOOK TO SEE IF IT'S SOMETHING OBVIOUS.. SHOULD HAVE A SET OF PINT, THEY CAN BE CLEANED WITH FINE SANDPAPER , LIKE THE STRIKER ON A MATCHBOOK
Jul 26, 2011 | DeLonghi 2507 Oil Filled Radiator Heater
Oil-filled heater smelling
yeah they do that, time for a good cleaning, if that fails, I'd replace with a ceramic heater... they are cheaper safer and cost less to operate.
Feb 21, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
Have lots of grime and dust on the internal radiator of our DeLonghi, how to clean?
Inside the rradiator, dust?. Let's assume you meant in the colis and fins. If #2 is the case, spray it with a degreaser and hose it out.
Oct 31, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi "The Incredible Heat Machine"
blows the house fuse after being on a few minutes
Feb 13, 2008 | DeLonghi EW0507 Oil Filled Radiator Heater
Leaking Oil from the front
DONT BUY A NEW ONE THEY ARE EXPENSIVE ... THEY PUT OUT VERY LITTLE ACTUAL BTU'S OF HEAT ...IT WOULD BE DANGEROUS TO TRY AND BRAZE ANY LEAK POINTS AND THE OIL IS NOT CAR OIL AND NEEDS TO BE FILLED TO FACTORY SPECIFIED LEVELS. (THESE ARE NOT MEANT TO BE RE-FILLED OR DOES THE OIL USUALLY DIASAPATE). OIL HEATERS OF THIS TYPE USE PLENTY OF ELECTRICITY. I SUGGEST A "HIGH QUALITY, THICK CASED, WITH TILT SAFTY, ELECTRIC SPACE HETER WITH A FAN. THEY HEAT PROBLEM AREAS SAFE AND EFFECTIVELY.
Apr 26, 2007 | DeLonghi 9707 Oil Filled Radiator Heater
DeLonghi TRD0715T Oil Filled Radiator Heater Logo
1,077 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
