Question about HP Pavilion dv6000z Notebook
Going on internet
When i go on internet pressing the small e in corner of screen it normally brings me up wi home page but its just bringing me up wi a page called malawerecore and saying i have aworm how do i get that page off
Is it on your desktop? If so, check out the properties of your icon (right click, "Properties," then look at the location of the link)
Otherwise you should try booting up in safe mode and running your antivirus software. Ewido and AVG are decent ones. To boot up in safe mode, press F8 when your computer is booting up.
Posted on Mar 01, 2008
  • HP Master
  • 19,396 Answers
If the problem was only setting up the home page you could do it easily from tools menu, then internet options then put right address in home page box. That page is a malaware itself. It means there is a kind of virus and will create more and more troubles in the future. the virus (lets call it this way in absence of detailed info) set up your page to that malawarecore software, which is a bogus antispyware. DO NOT INSTALL SOFWARE FROM THAT PAGE, even if it is telling that it will clean your computer. It will only open your computer's backdoors to more malicious software.
Using this link you can download a genuine malicious software remover. Be also sure you have your antivirus working and up to date. If you do not have an effective antivirus here is a free one.
If you cannot get rid of the bugs using this software you may need to contact a technician in your area.In London we do this kind of job for 50 pounds, it may be cheaper in other areas.
best regards
Brand new. reading book. cannot figure out how to get back to home page
tap top let corner of page. That should bring you to a list of options, like change font size and other icons. tap the corner again and you should be back to main menu listing. tap the book name when finished to go back to where you left off.
May 17, 2016 | Amazon Kindle - 6 Inch E Ink Display...
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
Hi, i have a acrr aspire one, it was not mine and can't get it to get wi-fi or internet, am not very good at this neither, i realy need help.
First, loof for a special icon along the top row of your keyboard. One of those keys turns wi-fi on and off. You may need to hold down the "FN" key while pressing the wi-fi key. Make sure that you have selected the wi-fi "on" setting. Next, you can try going somewhere that has free wi-fi such as a Starbucks coffee bar or a restaurant. Open your internet browser (Internet Explorer has a large blue icon of the letter "e"). See if you get on the internet. If so, your wireless adapter is working OK. Now, most homes have wi-fi that is password protected. Click on the little bar graph icon in lower right corner of your screen and a list of available wi-fi networks should appear. Choose your home wi-fi and click on Connect. This will open a screen where you must enter the passwordor passphrase to gain access to the wi-fi. Good luck.
Nov 13, 2014 | Computers & Internet
How to turn on ringer on hydro xtrm kyocera cellphone
There are two ways. On the left edge of the phone, near the top, is the volume button. Turn up the volume by pressing the top of the rocker button, down lowers the volume.
You can also mute and unmute the phone from your home screen. Press and drag your finger from the upper left corner, down. This will bring up the "Notifications" menu. Across the top are 5 icons (Wi-Fi, GPS, Bluetooth, Sound, and Airplane mode). If the sound icon says "Sound on", you can press it and it will switch to "Vibrate", and then "Silent", and then back to "Sound On". Hope that helps!
May 02, 2014 | Kyocera Cell Phones
Delete ask.com as browser and get google.com back
When your internet is up go to the upper left hand corner and bring the drop down list that has "manage add-ons" In that section you can turn off and delete tool bars/search engines you do not want. You may have to go to the Google start page to select Google for you home page. This can also be done under the Internet options button.
Apr 20, 2014 | Google Gmail
How do i get into my gmail account
Go to the Google home page and run your mouse to the top right corner of the page. Gmail icon should appear, then click on it and log in.
Or from Google search just type in "Gmail" and it will bring you there, or close enough (might require one more click).
Jan 19, 2014 | Computers & Internet
My KC550 lg does nt run internet .I received settings also but it give s communication error.why?
First what is a KC550 lg , laptop , deskop , mobile phone.
Im assuming phone have you synced with the wireless router ?
Connecting your LG phone to wireless Internet is easy to accomplish with phones that can receive Wi-Fi signals.
You may decide to use the Wi-Fi capabilities in the event that you do not receive the best signal from your wireless provider at your home or office.
If this is the case, then hooking up to a Wi-Fi network near you could provide you with a faster connection to the Internet and a more reliable signal to send e-mails, texts and pictures.
Press the "Applications" tab on the home screen of your phone.
Scroll down the list of applications until you reach the "Settings" option.
Press "Settings" to bring up the menu.
Locate and click the "Wireless & Network" or "Connections" option within the "Settings" menu.
Select the "Wi-Fi Setting" or "Wireless Manager" option, then select the network that you want to connect to and click "OK."
All of the available wireless networks within your range will appear.
Enter the wireless network password (usually located bottom of router) if you are connecting to a secure network.
Press the "Done" button followed by the "Connect" button.
Jul 26, 2013 | Computers & Internet
Hi my gmail page lost 'sign out' button and sometimes as soon as i go to gmail.com it brings my emails with out me signing in can you help me how to bring the things back to normal? thank you
Look in the top right hand corner of your GMail home page when you are signed in.
You should see your email name up there with a down arrow beside it.
Click on the down arrow and select SIGN OUT.
Then next time you sign in to GMail make sure you UNCHECK the STAY SIGNED IN box underneath the username and password boxes on the GMail sign in page.
Thank you and good luck.
May 23, 2011 | Google Gmail
How to connect htc p3450 to wifi..
Start out by bringing up the cube, but this time press the Comm Manager button and then press the WLAN button. This will turn on the Wi-Fi “radio” inside your phone. If you are within range of a Wi-Fi signal (your home network perhaps) a wizard will pop up on the bottom of the screen indicating wireless networks that are within range and it asks you to “Select a network to connect to:”. These are “access points”, or commonly referred to as “hotspots”. Chances are there will be more than one so simply tap on the name of the one that is available to you and that you know the password for if necessary.
The next window will ask you to select if the access point/hotspot you selected connects to the internet or to “Work”. “Work” indicates a private network, so chances are you will want to tap on “the internet” as your choice. If the network you chose is “security enabled” you will be asked to enter the “key” (password), then press “connect”. If it is not a secure network, do not enter anything and just press “connect”. Look at the top of your screen and notice the Wi-Fi status indicator. When the arrows stop being animated and the little tower icon has a solid circle around the top part you are connected to the network and ready to surf. The next time you are within range of this network you will be able to connect automatically within seconds of turning on Wi-Fi in the Comm Manager. You only have to go through this setup procedure each time you connect to a new network for the first time.
Once you have connected to a Wi-Fi network, the settings will be saved and you can see/edit/delete these settings by tapping on the soft menu labeled “Settings” from the Comm Manager page. Choose “Wireless LAN” then press the left soft button labeled “Menu” and choose “Wi-Fi”. There you will see the network names that are available to you now, or that you connected to in the past. If you will not be using a particular network again you can delete it by either pressing directly on the name of it long enough to bring up a menu that has “remove settings” as a choice or by highlighting the one you want to delete and then pressing the right soft button labeled “Menu” and choosing “Remove Settings”.
Once you are connected, press Comm Manager’s left soft button labeled “Exit” or tap the “X” in the upper right-hand corner then bring up the cube and press the “Internet Explorer” button. Then you can go to whatever web page you want.
Mar 02, 2010 | HTC Touch P3450 Smartphone
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
