Question about Whirlpool AWM8163 Front Load Washer
AWM8163 Cylinder revolves with friction - sock?
The machine is not running. The cylinder does revolve when I spin it by hand - but with some friction (it was really stuck but I manages to fix it with blunt force...). I get an error message (can't remember which one). It feels like something is stuck between the cylinder and outer casing (sock?). Can I open the machine to remove the obstacle? All the best!
    Sergeant:
  • 351 Answers
Try removing the element then use a coat hanger to removr sock
Posted on Apr 03, 2008
  • 156 Answers
Its very long diffecult job to do that but i have had luck going to the bottom of tub removeing the drain hose from tub to pump work things out throw the 3 in hole in the bottom
Posted on Mar 03, 2008
How do I remove the cylinder from a over Johnson.22 revolver? SN starts with a "K"
Not enough info. Top break ? Serial Number ?
GunParts' website may can help you. They have schematics and parts lists that you may be able figure out what you need to do.
Iver Johnson Revolvers Gun Parts
Oct 08, 2017 | The Optics
How do you tell the difference between the 7-shot and 9-shot barrels of an H&R 22 Special revolver?
Open the revolver portion that holds the rounds and count the number of rounds. Has nothing to do with the barrels but the cylinder itself behind the barrel.
May 24, 2017 | The Optics
I just got a revolver smith and wesson barrel says 38 s&w special cartridge. Inside frame with cylinder open is stamped 4379 and sn on bottom of frame is 279032 Thanks
a few different model S & W 38 cal revolvers made
can you add a photo to your question
do you have measurements of the barrel
Smith Wesson
contact a S and W collector or gun auction or dealers web site
Guns for Sale Gun Auctions
Mar 06, 2017 | Sport & Outdoor - Others
I have a Rossi 38 special 5 shot revolver made in Brazil and imported by the Garcia Corp. Near the cylinder is stamped C 630 whatever that means and the serial number is D297609. I called Taurus but they...
https://www.gunvaluesboard.com/i-have-had-a-rossi-interarms-38-special-stainless-steel-5-shot-revolver-for...-30725949.html
Maybe that web site could provide more assistance to you.
In the web site above it states in a discussion that the: "M88 revolver started with W.
N"Hi, This is want I can tell you about Interarms imported Rossi revolvers.
Don't know about other importers.
Model 88 (5 shot SS 38special) had W prefix followed by six digits.
Model 68 (5 shot blue or nickel 38 special) either had D or AA prefix followed
by six digits.
No part or serial number or prefix indicates month/year etc.""
Feb 08, 2018 | The Optics
I have a suffolk punch 14sk which starts runs and cuts excellently the only problem is that on starting the cutter blades revolve all the time and will not stop even on slow idle speed. What is the...
NO dont change the belt, chances are its just the cable needs adjusting, slacken the 10mm nut on the adjuster that goes into the casing on the left side of the machine ( think its the top cable that adjusts the cylinder) after the nut is slackened off turn the adjuster clockwise so its going into the casing,you can do this while engine s running. the cylinder should stop turning as you wind in the adjuster. I would also suggest that the cylinder is turning too easily and it will need adjusting by turning the adjuster screws either side of the cylinder. turn the adjuster screws clockwise one click each at a time until the cylinder just touches the bottom blade when you spinn the cylinder by hand( with the engine NOT running!!!!!)
Feb 25, 2015 | Garden
Bobbin winder won't spin Cannot load bobbin because the spindle does not revolve otherwise machine sews well.
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Sep 30, 2010 | Brother XL-2230 Mechanical Sewing Machine
Call for service CEA0
This means the revolver (holds the 3 color toners/developer units) never returned/moved to its "home" position.
It could mean a bad or dirty home position sensor or a faulty/bad logic board or possibly a bad motor (not rotating the revolver correctly) try cleaning or replacing this sensor first.
if you remove the covers from the left side of the copier you will see the revolver unit. the sensor is located at the rear of the revolver unit mounted on the frame of the copier.(easy to see) there is one screw holding it and a small wire connector.
These copiers are "famous" for having dirty sensor issues.
If the revolver/machine makes an odd noise when starting up, caused by the revolver then its starting to turn (run the copier with the side cover open so you can watch it) then it would point more to being a drive problem.
Mar 26, 2009 | Toshiba E-Studio 3511 Color Copier
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Whirlpool AWM8163 Front Load Washer Logo
94 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
