Question about Motorola Mobility RAZR V3
Charging my phone will not charge have tried to charge with a new battery and different chargers
    Brigadier General:
  • 7,752 Answers
You need to have the charging port check to see if it needs to be replaced take it to a mobile service center and have it checked out there.
Posted on Apr 14, 2008
How can I retrieve contact numbers from my fone that has discharged and wont charge
My phone died and now won't power on or charge. Here's how to fix it. Did your mobile phones battery drain all the way to zero and now your device is completely dead, not powering on or not even letting you charge it? This article will go through some tips on how you might be able to revive your dead phone.
If your cell phone is a smartphone then this is a reasonably common issue. It used to be a general practice to run older batteries to zero battery life before charging them back up to full again but try not to do that on the new smart phones, they use lithium-ion batteries which discharging 100% is a major concern and isn't good for the health of the battery.
If your battery has drained to zero and now the phone won't respond then try this
Pull the battery Start out by pulling the battery out of the phone for a few minutes then put the battery back into the phone, put the phone all back together and then plug it into your ORIGINAL charger that came with the phone. Make sure that you use the original charger that came with the phone. If you don't have the original charger then make sure that your charger is a manufacturer approved charger. If your battery is built into the phone and you cannot remove the battery from your smartphone then try to perform a simulated battery pull. Many phones have a method to restart the device, usually by holding down specific buttons or keys on the device. Much like the Motorola Atrix HD simulated battery pull or the Sony Experia simulated battery pull where you hold the volume down key and power key simultaneously while the phone is powered off.
Check the outlet Sometimes we can be too close to an issue and can overlook something as simple as a wall outlet attached to a light switch that's turned off. If the light switch is designed for turning off and on a light and the switch is off then there is no power coming from the outlet and obviously your device isn't going to charge.
Try a different outlet This can go hand in hand with the above suggestion. Try a different outlet to make sure it's not a power socket issue.
Try using a computer or car charger Using a computer or car charger instead of a wall charger can sometimes put a quick charge on your battery and get it to respond as well. Keep charging it If you have tried these methods and your phone isn't responsive due to its battery being drained 100% then it can be difficult to get your phone to charge again. Try charging it for at LEAST a couple hours on an outlet you know to be working, even all night if possible. Lithium ion batteries can take a while to get to charge again if drained all the way. So try charging it for a while, You might need a new battery If you try these tips and suggestions or have tried all these things already and there is still no response, and your phone is completely dead and will not recognize a charger then you might need to try another battery.
Try a different charger If you have tried a different battery then make sure you try your original charger first, as mentioned above. If there is no response then it might not be your battery but your charger that has malfunctioned and might need replacing. If you have any spare chargers try those to see if you can get a charge out of your phone. Replace the device If you have tried a different battery and a different charger and your phone is still little more than a paper weight then you should start reviewing your phone replacement
Sep 30, 2016 | Cell Phones
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Phone won't charge or hold a charge - tried 3 different chargers and a new battery. Cleaned all connection points with alcohol. LG Vue
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
Jun 02, 2010 | LG Vu CU920 Cellular Phone
My phone is fairly new ( a few months old) and for some reason the charger wont charge when I plug it in. I've tried unplugging it, putting it in different outlets, taking the battery in and out etc but...
i think your baterry is drained already..try to charge your battery in a universal charger, or a clip charger.then continue charging with your original chargermoz-screenshot.png7bf4754.jpeg
Apr 13, 2010 | Motorola Mobility W376 Cell Phone
The battery is not charging when I plug my phone in. I have tried different chargers as well as a new battery.
Since you tried different charges and a new battery may be the charging jack in your phone has loose contact .i mean the board of your phone.also check the charger IC.
Mar 05, 2010 | Motorola Mobility RAZR V3
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
You have 3 options when the charge port breaks.
1. get it repaired, under warranty if possible
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
Battery wont charge in phone or charger that came with it? how can I charge it?
battery may be bad and need replaceing, or the charger has a short in it or is not functioning properly. if you plug the charger into the phone its self the phone should come on with or without the batery in it. if it dont then i'd try a different charger or get a new one.
May 10, 2009 | Cell Phones
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
