Question about Mitsubishi VS-50605 50" Rear Projection Television
Tv problem After I replaced IC951 everything work but after warm up none of the controls work. The remote contol or buttons on the tv. All are dead. Now what? REDCAT55
  • Mitsubishi Master
  • 8,617 Answers
Check the connections on your front control panel PCB to see if they are all secure then trace them back to where the plug into the chassis and check the connection there as well
Posted on Mar 01, 2008
Remote with TV stopped working for vol, AV, and mute. Only power button works. Used new Batt; no change. Used buttons on TV; none work there too. Is there something broken on TV?
If the buttons on the TV -and- the buttons on the remote don't work, then there's definitely something wonky with the TV.
The good news is that the power works and the picture looks good. That rules out a bunch of things. If you don't mind tinkering, replacing circuit boards on TVs is pretty straight-forward -- just take off the back, unscrew the offending board and replace it. You'll have to do a little research to narrow down to the right board to replace -- it might be this key controller board:
http://www.shopjimmy.com/panasonic-tnpa4280s-gs-board.htm
May 04, 2016 | Panasonic TH-50PX75U Plasma HDTV
Suddenly my remote no longer communicated with the tv. I replaced the batteries in the remote. Still no communication. I can operate the tv with it's buttons, but the remote has no effect. Is there any...
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Jan 03, 2011 | RCA L32HD31 32 in. LCD HDTV
Since last night unable to change any stations with my remote control. when I puch the Power button the TV light comes on but everything else is dead. Have changed the Bat.....etc have tried to...
Hi, I would like to help you out.
Please go to your nearby hardware shop to change your remote, because someone would have dropped it and so it is not working fine. the board of the remote control could have been damaged.
please let me know if you have any doubt and vote this solution if you think this might help others :)
Thank you :)
Oct 28, 2010 | Televison & Video
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Contoller wont connect to my xbox 360 i get four flashing green lights on the remote and none on the console
press the controller locator on your console it should work. also press the same button on your controller.
Dec 22, 2009 | Microsoft Xbox 360 Controller
None of the controls work on my 32 in. lcd hd tv. the remote will not work nor will the controls on the side of the tv. what do i do
Take it aparts change the side controller board it dead.The board it dead that why remote control or side controller not working.
Dec 05, 2009 | Polaroid 3211TLXB 32 in. LCD Television
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
TV problem
Let me go over the schematics and I will post what i can find that maypossibly keep taking out the IC
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
DEAD TV
Look for 2 resistors off of pin 2 of IC951 R955 & 956 they are hooked in parralell and the tail end of those resistors are grounded.
Feb 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Jan 30, 2008 | Televison & Video
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
