Question about RCA P52926 52" Rear Projection Television
Convergence off and gone from menu
My set worked flawlessly for 6 years, then one morning band... I see three of everything one in each colour of my bulbs. I tried to ajust the colour centering but it is all gone from my menu...tried 3D glasses those didn't work either.
    Sergeant:
    Champion:
  • 250 Answers
Hi, Here is a good write up on how to fix this problem. Please be careful doing so.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Mar 01, 2008
My colour is red and doubled (kind of 3D) but the sound and everything else works fine, what do i do ?
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2011 | Sony KP-53XBR200 53" Rear Projection...
My picture has broken into colour ghosting (it looks like a 3d picture without the glasses on). I'm guessing that this might be the failure of one of the colour bulbs. The wavey colour bands that I see are...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 31, 2011 | Hitachi 57F500 57" Rear Projection...
My tv has a color seporation on the screen, at the top it has a yellow band, and at the bottom it has a blue band. what could the problem be, and what part will i need? thanks kevin.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 28, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Tv showing two pictures. it is blurry and mostly blue, red in colour
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Toshiba 42H81 42" Rear Projection...
Whys the only colours on my tele are green n pink?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 12, 2011 | Televison & Video
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
Mitsubishi WS65809 HD input (DTV) not working correctly. I replace the convergence chips in this TV and was making adjustments in the service menu. Everything was lined up and working great. The HD input...
All these sets do have a hard reset---not the reset button on the front of the set---it will return the set to the factory original condition it was when new in the box--it will not affect the convergence as that is stored in a separate unit--the DCU (digital convergence unit).
It is accessed with an original MITSUBISHI remote.
You can try it if you want:
ACCESS CODE FOR WS65809 IS:
menu-0,1,7,0 enter
There are 3 hidden menus in the set--this is the Option menu
You will see either reset or option etc and highlight it with the remote and hit enter. Set will shut off and should come back on channel three in the air band--any labels you placed on inputs will be gone and set will be in air band--you will if on cable have to change it to cable band and auto program etc.
Let me know what happens and if you have questions I am here to help.
SD TECH
Feb 02, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I have a Panasonic HDTV and suddenly the colours went double!
hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
Feb 02, 2010 | Panasonic Televison & Video
Menu (SCREEN) #4 Adjusting projection is gone
you have a convergence problem and this can only be serviced by a tech with the know how to service the rca projections sets as there are many alignments in this set and some are manual driven but mosrt are on screen driven. You need the know how to get into the service mode. Sorry my friend but my recomendations would be to send this set out for service.
Jun 08, 2006 | RCA P56812BL 56" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
