Question about Lite On (LTN486S) Internal 48x CD-ROM Drive
Using master, slave or cable select jumper
I can't see any markings on my CD ROM drive for the master, slave or cable select jumper positions.
Does anyone have a manual or diagram that shows the jumper placement?
Thanks!
  • Anonymous Mar 23, 2008
    i have 1 hard disk and one dvd drive, when i install both i cant see my dvd when i open window xp (dvd Not working)
    Master:
  • 377 Answers
Using master, slave or cable select jumper - 89c8602.gif SETTINGS:
A - Cable Select Mode
B - Slave Drive Mode
C - Mater Drive Mode
Enjoy!
Posted on Mar 01, 2008
  • pincer
    pincer Mar 01, 2008
    Thank's Bill..
    See you around again..
    Kindly regrads,
    pincer-
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
In my computer CD drive is not listed .I changed the jumpers from master to slave and slave to master. CD drive has got power it opens and close but not reading CD/DVD even it is not listed.model t3304.my...
Make sure the data cable is fully connected to the motherboard and the CD-Rom drive. If this is an IDE drive, make sure the jumper choice matches the position on the cable (the 40 pin wide ribbon cable that supports two drives). It also needs to be correctly oriented in the unit - the red stripe on the edge marks the side that goes to pin 1. Only use slave if there are two drives connected to the cable and the CD-rom is on the slave connection. (Note the connectors are black (motherboard), blue (master) and grey (slave) on a standard IDE ribbon. Newer IDE drives have a Cable Select option that you can leave the jumper set to and avoid issues of getting the connections wrong.) If it uses a SATA cable, the jumper should stay as Master (IIRC). If available, try a different connection on the motherboard for the data cable. (Some modern motherboards only have one IDE connector.) If you have any sort of IDE to SATA converter in use, try a direct connection in case the converter is damaged. SATA cables sometimes are designed to latch into connector on the drive so make sure it is fully seated.
Replace the cable if it still isn't connecting. Then check the status of the drivers. In Windows, use the Control Panel and go to the Device Manager. Look to see if the unit is listed with a red X or yellow exclamation point in a triangle. Try to update the driver.
If the above suggestions do not help, you should consider a new optical drive.
I hope this helps.
(I have frequently seen a non-responsive drive due to a loose data cable.)
Nov 22, 2010 | E-Machines emachines (emachinees) CD-ROM...
How do you set master slave on this drive
On the back of the drive, there is a group of 8 pins grouped in 4 pairs next to the power connector. 3 of these will be marked MA (master or master with slave), SL (slave), and CS (cable select).
The Teac may have the jumper selection printed on the label on the drive.
Sep 22, 2010 | Teac CD-224E (cd224eb33) CD-ROM Drive
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
Bios Fail to detect Local Disk C and DVD-RW
I'm going to make an assumption here and guess that you have both hard drive and cdrom plugged into the same IDE cable. I think you have either 2 masters or 2 slaves and that is why the bios can't see them. On any one cable you can have a master and a slave. Drives have to be jumpered to configure them as a master, slave, or cable select. Cable select requires a certain kind of cable but in that system the master is the drive plugged into the first plug-in away from the motherboard or the middle plug and the slave is the second one or end plug on cable. If you can jumper cable select and then plug the hard drive into the middle plug on the IDE ribbon and the CD rom to the end one then you'll have a master and a slave. Bios should then read the drives. If that doesn't work then you have to jumper the hard drive to master and cdrom to slave. The cdrom is marked on the back as to which jumpers you use. MS/SL/CS. master/slave/cable select. The hard drive usually has jumper settings on the front of the drive but you might have to look up on manufacturer's web site. Most computers use cable select now.
Dec 06, 2009 | Audio Players & Recorders
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Slave Jumper Position
ok......it is easy to do such, just place the jumper on the first : and enter the system setup them test if it is on slave if not repeat the same for all the ::::: untill you get the slave and cable select.
Sep 08, 2009 | LG (CED-8080B) CD-RW Burner
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
Lite On (LTN486S) Internal 48x CD-ROM Drive Logo
1,171 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
